FS: IS20 Turbo with APR Cast TIP $200.00 plus shipping.
mk7-k
Delaware
2016 'S' 4 door DSG
I'm selling an IS20 Turbo with an attached Cast APR TIP, about 30,000 plus miles. The Turbo needs a Wastegate Actuation Motor. I just installed an APR DTR6054 and the installation says ' the system reuses your factory electronic wastegate and electronic diverter valve from the IS20'. That's the reason it needs a wastegate.
$200.00 cash plus shipping or if you live near Dover DE. you can pick up or I could meet halfway from where you live.
mk7-k
Delaware
2016 'S' 4 door DSG
bump
mk7-k
Delaware
2016 'S' 4 door DSG
I like it so far. I came from an APR Stage 2, still have the APR catted downpipe on, so they had to put an 02 sensor after the cat. The car has a more linear feel as far as acceleration, unlike the Stage 2 grunt it had before, but once the car hits about 3800 RPM, it goes. Unlike Stage 2 when you had a High torque or low torque option with 91 or93 octane, they now offer 2 wheel drive or 4 wheel drive option. The 4 wheel option (obviously for 'R') models gives you more power in the lower RPM's, so you'll burn more tire, We set mine to 2 wheel drive and I went into OBD11 and changed the Throttle Response from Standard to Responsive. I haven't really tested that, don't know if will make a difference. If you do this, you should get an Intercooler, decent intake and the Charge pipes. APR tells you this in the ad. Where would you get it installed since you live in Delaware? Good luck.
mk7-k
Delaware
2016 'S' 4 door DSG
bump
mk7-k
Delaware
2016 'S' 4 door DSG
Bump
