FS: GFB+ dv *new*
Johnny Blaze
SFV 818
For now im stock, and just didn't get around to install it. Just sits there, i might get one back later on, i would like to possibly get a DP installed, OEM tune. :)
Deviation01
St. Louis
Can someone explain the benefits of this in a simpler language. I am familiar with what diverter valves do but why is this better then the stock?
ami91sun
Cotati, CA
Diverter valve is there to release pressure on the turbo as well as assist with turbo lag. Therefore with a DV upgrade you get, better throttle response, stronger boost & holds boost better, etc..
ami91sun
Cotati, CA
Is that change the sounds when you shift?
Not sure if I'm understanding correctly, I think you might be thinking about Cold Air Intakes. Do a search on Youtube for Cold Air Intake Sound Clips and see if that is the sound you are talking about.
