FS: 2019 MK7.5 OEM GTI LED (NAR) Tail Lamps (low mileage)
quailallstar
WOB DJ496
Florida & our Nation's Capital
MY19 MK7.5 GTI Bunny
SOLD
quailallstar
WOB DJ496
Bump and pictures added.
ZERO815
Köln Germany
2017 GTI SE DSG
They work on MK7 but vehicle connectors are different (MK7.5 8-pin-all instead of MK7 4-pin-outer and 5-pin-inner), coding is different too. No need for a harness that connects inner and outer lights, adapters on each light are enough.
quailallstar
WOB DJ496
Thanks for chiming in Michael!
quailallstar
WOB DJ496
Is there coding and adapter info for an MK7 anywhere? Everything coming back is related to the European models
thanks
@ZERO815 do you also make harnesses for this application? By the way, I ran all wiring and installed the Euro harness you made for me. Phenomenal work and quality with your harnesses.
quailallstar
WOB DJ496
Bump! Lights are off the car and ready to ship!
9uns
gti
damnit...put these away and bring them back out after the covid pandemic. i'll buy asap. :)
quailallstar
WOB DJ496
Let me know!! These may not be around as long as the darn Covid 19 will be... ;)
quailallstar
WOB DJ496
Bump! Lights are all boxed up and ready to ship :cool:
2019_GTI_SE
California
Are zeros harness plug and play? Or are there some electrical skills I needs such as soldering, butt connector, crimping, etc that I will require to do once I receive the harness?
With his harness, will I have to tear apart the panels on my hatch?
Would you be able to send me the directions for his harness install?
I'm trying to pre-prep which harness I want to go with :(
quailallstar
WOB DJ496
His harnesses are 100% plug-n-play. I would highly recommend you go with him. The quality is OEM and I would even say better.
I don't know if the NAR harness for LEDs requires you to remove any panels in the hatch.
When you purchase from him he provides instructions. I recommend you contact him directly as he can better explain this particular harness.
Let me know if you are still interested in my lights.
quailallstar
WOB DJ496
Bump!
