FS: 0A5141671F All Metal Throwout Bearing - OEM - NEW
crxgator
It’s a popular upgrade? For the MK5/6 yes. If it was truly compatible with the MK7, VW would have used it in the MK7 as opposed to making a totally different one from the MK5/6.
Please show me where this is shown as a true upgrade. If it is an upgrade why didn’t you use it in your car instead of the plastic one?
nonegiven
Midwest
Many people on this forum have upgraded to the all-metal throwout bearing when upgrading their clutches. Perhaps you're not familiar with the search feature.
ian124
California
Your point? VW switched to a plastic oil pan for the mk7 but the metal mk6 pan fits and is clearly an upgrade.
crxgator
Because the aluminum and mk5/6 plastic version has a thicker spacer than the MK7 which could potentially cause issue depending on the clutch setup.
And why do you think the metal oil pan is an upgrade?
nonegiven
Midwest
The measurements are already posted on this forum. The height difference is very small but gives the MK6 TOB a lower engagement point.
Boondock
Chicagoland
Ride
2015 GTI S
Use caution when choosing this TOB. Using a Mk5/6 TOB included in my first clutch kit caused the clutch not to fully disengage, burned up the clutch in 2 weeks and it needed to be replaced a 2nd time.
nonegiven
Midwest
LOL You used the TTRS setup that's been discontinued by FCP Euro due to lots of engagement issues. Many people have had to rip that clutch out and start fresh. They issued me a full refund for my clutch and paid for 100% of my labor for the exact same issue and I was using the plastic MK7 TOB.
