Ezekiel81923
- Royersford, PA
- 2019 Volkswagen GTI
Arms just came out with a true fmic as well which is basically the same as Bauns they both use the same vibrant 12810 core.
Where do you see that?
See what? That they both use vibrant 12810 cores?Where do you see that?
you're missing something lol heres the link for the direct bolt on true fmic kitThat they released a true front-mount set up? On their website they only have the stock location replacement intercooler. Unless I'm completely missing something here.
https://www.armmotorsports.com/collections/vw/products/mk7-fmic-kit
I like the direct replacement intercoolers over FMIC for various reason. Most of the time you need to leave the stock intercoler in when doing a FMIC due to it holding other thing in place. So you keep all that weight and now its just a block of metal getting no flow internally to dissipate heat (unless you are running a twintercooler setup).
Just FYI, or you know already - the stock intercooler is very light and flimsy, it's one of the reasons it is so much worse than the aftermarket ones since thermal mass actually matters in an open loop cooling system like an intercooler.
Does the AC performance really suffer from the FMIC? I find it ridiculous that the AC condenser is just hanging out there with no protection, on my golf R the AC condenser was hit by a rock and died in the first 2k miles.
Great thanks for the feedback. I really want an FMIC and the protection for the condenser. Two birds with one stone!I haven't noticed a difference. It's been 100+ here in So Cal.
Yup, you can tell from the picture and the finish’s that it’s NOT a vibrant core, it’s a knock off of the vibrant core.I don’t think ARM is using authentic Vibrant cores for two reasons.
-Vibrant just increased pricing by 20%, so their retail price is in the negative unless they’re buying every component as cheap as possible and having it built in China.
-A customer PM’d me a picture of the ARM kit and the intercooler itself looked like it was straight off of WISH lol.
Anyway there’s something out there for everyone and even if it’s bottom of the barrel components it’s better than the eBay bicoolers by design so it has some positives to it.
Also, here’s one of my kits FS lightly used (I don’t own it, contact info in the thread)
https://www.golfmk7.com/forums/index.php?threads/used-baun-performance-fmic-tx.377920/
Must be a knock off then cause the dimensions of Arms core and Vibrant are the exact same.I don’t think ARM is using authentic Vibrant cores for two reasons.
Mine, Authentic Vibrant
Questionable rough finish even overtop of the welds on ARM. Unless it’s a rendering it doesn’t appear to be Vibrant
There are less costly alternatives.
Have an understanding of your vehicle's Cooling System - there is an A/C Condensor, I/C, and Radiator in the stack. Air flows in that direction.
When opting for a FMIC, know that the air flow through the Cooling System is greatly reduced. FMIC type set-ups that piggy-back on the stock system are effective, but at the cost of affecting the rest of the system.
Just about every Stock location I/C will be more costly.
At a minimum, I would recommend a stock location I/C set-up over a FMIC - regardless of brand or type.
I just recently went Cobb stage 1 with a CAI and a DSG tune and want to add an exhaust but Cobb is suggesting I add a FMIC before doing so as I will get heat soak. Their intercooler however is around $900 and was wondering if any of you have gone through Cobb, and if so is there a cheaper alternative to their FMIC?
