Fitting the GTI LED tail lights on Highline - retrofit.
sigi_dr
belgium
damn.... my notebook just broke...i'm so f***ed up now. i think im going to bring my car to vw workshop and ask them to revert the coding back to default (factory setting) and i hope they can do it.....
yes only 1 wire to route from outside to inside (outside to pin no.3 and inside to pin no.1)
once again, thank you very much for your time helping me
Ehm, are you sure about those pin numbers? it should be from pin3 to pin3...
That's why everyone says: before doing any coding, backup all your default settings in a VCDS channel map..
Now, unfortunatly, it will cost you money...
But you know what.. i'll do you a favor, details in pm
Grtz
rafikiraf
VIRGINIA
Ok. All day is not going as planned.
I did led taillights mod before same way bcm to taillights harness. On 2015 gti I used hs tuning harness and coding and all was perfect. This time on 2017 R I used sigi_dr version. I don't know what did I do wrong but something for sure. This is outcome with outer blinkers. They stay solid on all the time and only inner blink when turning. Please see picture when blinkers are off.
Please someone point me to the right direction.
Sent from my SAMSUNG-SM-G935A using Tapatalk
sigi_dr
belgium
So everything else works as it should?
Can you make a channel map please, and post here the values you have in 16blk and 17blk
Grtz
rafikiraf
VIRGINIA
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16100
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 160
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 160
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 160
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 160
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 160
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 1633 - LED-Modul Blinkleuchten
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16Blinken links Hellphase
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16not active
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16not active
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16not active
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17100
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 170
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 170
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 170
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 170
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 170
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 1733 - LED-Modul Blinkleuchten
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17Blinken rechts Hellphase
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17not active
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17not active
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17not active
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18100
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 180
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 180
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 180
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 180
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 180
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 1838 - LED Blinkleuchten
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18Blinken links Hellphase
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18not active
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19100
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 190
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 190
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 190
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 190
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 190
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 1938 - LED Blinkleuchten
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19Blinken rechts Hellphase
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19not active
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1127
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 10
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 10
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 10
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 115
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 13E
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 133 - LED-Modul Blinkleuchten
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1Blinken rechts Hellphase
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1not active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1not active
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1not active
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20maximize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20100
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 2010
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 200
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 200
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 203D
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 2013
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 2034 - LED Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20Brake light
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20not active
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20not active
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20not active
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21maximize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21100
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 2110
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 210
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 210
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 213E
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 2123
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 2134 - LED Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21Brake light
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21not active
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21not active
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21not active
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22100
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 220
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 220
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 220
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 222C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 2229
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 2242 - LED dritte Bremsleuchte
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22Brake light
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22not active
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23minimize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23100
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 2310
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 230
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 230
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 230
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 230
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 2334 - LED Bremsleuchten
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23Always
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23Brake light
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23not active
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23not active
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23Blinken links aktiv (beide Phasen)
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24minimize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24100
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 2410
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 240
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 240
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 240
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 240
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 2434 - LED Bremsleuchten
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24Always
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24Brake light
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24not active
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24not active
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24Blinken rechts aktiv (beide Phasen)
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25127
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 250
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 250
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 250
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 2530
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 2528
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 2543 - allgemeine LED
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25not active
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25not active
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 2663
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 260
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 260
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 260
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 260
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 260
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 261 - LED Tagfahrlichtmodul Versorgung
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26Always
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26not active
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27maximize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 2710
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 270
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 270
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 270
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 2747
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 270
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 2732 - allgemeine LED bis 12W
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27Always
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27not active
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27not active
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27not active
rafikiraf
VIRGINIA
Yes everything works OK. Just outer blinkers are solid at all time and they are on as soon as I turn lights on. Only inner blinkers blinks when required.
lonn2se
Sweden
Hi all.
Super this forum. I do my Led tail lights next week like Mk7norway.
Is this coding funktion after mounting the Leds ?
Select -> 9 Central Electronik -> Security Access -> 31347
Adaptation -> Channel: (4) Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A16: Set = Blinken lins Dunkelphase. (Default:Blinken Links Hellphase)
Adaptation -> Channel: (4) Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A17: Set = Blinken rechts Dunkelphase. (Default: Blinken rechts Hellphase)
sigi_dr
belgium
Hi all.
If you read the howto mk7norway wrote you will notice you don't need any coding...
Coding is only needed if:
- You have an US golf (since you're from Sweden, not the case)
- You want to some specific coding like alternating blinkers (in which you will have to follow an entirely different howto)
Grtz
SonicAaron
Belfast
Grtz
This post is interesting because the thread was too long to read and it seemed like fitting these was a ton of work.
As a U.K. Golf owner are you saying it's simply a case of buying them and having someone fit them almost a straight swap? Aside from getting the inner indicator to work as that needs a wire run from the out to the in. Is that wire already on the originals or is it a messy job.
sigi_dr
belgium
If that wire would already be there, it would have been plug and play, so no it's not there...
The moment you plug in the LED's they will already function, ony the inner blinkers and bi-color led will need extra wiring...
So you could perfectly buy the lights, put them in yourself and drive around like that until you find someone who could do the extra electrics for you
Grtz
lonn2se
Sweden
Grtz
Hi. I have read all. I mean the dynamik blink coding if you look...
I can understand it will not funktion cause no wire to BCM?
sigi_dr
belgium
If by dynamik you mean the LED taillights from the mk7 facelift, i doubt it will be easy...
For starters they have to fit, history tell's us facelift taillights don't allways fit properly without modifications (Polo 6N and 6N2)
Secondly i don't know if they would work on the pre-facelift BCM...
Grtz
