Fitting the GTI LED tail lights on Highline - retrofit.
sigi_dr
belgium
sigi_dr
belgium
Ok. How about the coding? Anyone now how to do it in vcds?
Skickat från min iPhone med Tapatalk
I would ask your dealer if they are willing to do the coding, their system automatically uses optimal settings for your region.
If they don't want that, you can do it manually, but it's a lot of coding...
Grtz
sigi_dr
belgium
I think it maybe better to fit this to have that function and not run the wire all the way.
http://m.ebay.de/itm/182155379071?_mwBanner=1
That's a nice alternative, just a bit expensive!
First time i see it, i like though!
Carsystems.pl is a known seller, i think its reliable..
Edit: if you buy these you can also avoid cutting original wires ;)
Grtz
comingabriel
Southeast
Grtz
There is a problem with carsystems, DAP, and other sellers of the same harness is that it does not have the red/amber trigger wire on pin 4, I had to make one.
vw1961
italy
help
boys you are very EXPERT ...... how can help me ?
i search the 2 connectors and the colours of the wires to
connect the front ORIGINAL led light PXA
and the connector and colours of wires of the rear led directional light ?
This connect for the NEW Golf 7 Restiling 2016/17 .
ho can help me please ? i think this schematic wires position and
colours i think is in Elsawin or Etkra program ?
help me ....:confused:
satel
Center of Europe
Hello guys
I was thinking of buying a Facelift back light, but I gave up on coding and problems.
I bought these lights : https://shop.ahw-shop.de/led-rueckl...tuning-leuchten-5g1052200-heckleuchten?c=7185
I'm waiting for DHL delivery
I read every page in this theme for installation!
my doubt is:
1. install by OEM instructions from BCM and coding ?
2. install easy (first page) - ( switch pin1-pin4 ) ?
Option 2.: I'm afraid when the direction light is turned on, will the two red LEDs be turned off? so that the yellow light is working!
OK : https://www.youtube.com/watch?v=zYkH_m6WHIE
No OK : https://www.youtube.com/watch?v=4i_nMAPwoWc
The last question: why in the illustration for the instructions of this installation go for 2 wires?
thank you
sorry for my eng, i am from europe
sigi_dr
belgium
satel
Center of Europe
Thx
is it better to do an oem installation?
I'm just afraid of BCM (how to get it) and where to put it, then coding it without being error on board
I would be grateful if you would help me when I was doing it for a few days
contact via Viber, Skype or e-mail
Coding and installation OEM
sigi_dr
belgium
Thx
Is it better? That depends on what you want, i wanted to be able to do all sort of crazy stuff with my lights (just for fun, i don't drive on the road with my lights in christmas/disco mode)
If you just want the LED-look, the 'easy' method is good enough!
If you are afraid, please don't do it.. even VW-technicians say it's more complicated than it looks on first sight..
satel
Center of Europe
Only problem OEM install BCM Unleash that I can wire it, other installation not problem for me :)
Coding with VCDS is not a problem? My car is from the Netherlands
satel
Center of Europe
This is the picture GUIDE!!!
Please ask me questions if you have any! :) Tried to explain the best that I could. We did everything we could to not touch the original electronic wires in the car. All the solder was added to the taillight it self, to provide us for making the bridge from Pin 1 to Pin 4. This will make the fog light and inner indicator work.
BEST FOR LUCK GUYS!!!!
We used about 1.hour on each side. :D
It's okay here as I can see it --- Fast installation, pin1-pin4 method
Lights turned on, turning light is full yellow, no red
