No ill tone taken. I was joking how you posted a couple days ago to get a wiring diagram then pow! zen tv interface. I can confirm on the mib 2 non nav, non fender speaker wire outs are not flat nor do the frequencies increase linearly. I just hooked up the audiocontrol dm810 that has input and output rta. The 400 to 1k range was spiked up while the sub for the most part was low. My max volume is 15/30 with the bass turned down 1 to avoid clipping 35 and 45 hz. I was hoping the rear speakers off the mib would be usable but the dm810 causes an audible delay to do its job. Like .25 or .5sec.
I was hoping to find a cheap most to toslink wire and code mine to use the most for better s/n ratio. Im sure the zen is a great piece of equipment, but I'm already too deep to jump into that. Saving my strength for an s3 or a3 is38. Then 3 way active up front. I think there's a spot for a 3.5 in the door.
Last car had a JL Fix (and TWK, later Helix) with optical out ... never sounded right to me even though it was a "flat" output. Thank you for all that detailed info! I haven't really caught anyone explicitly saying they tested if the signal was flat. Let me know if you ever figure out something out, the whole MOST system is new and foreign to me.
I'd say keep holding out for the S3 the only reason I leaned towards the GTI instead of S3 was because at the time I wanted to be able to eek out the smallest (and still fun/practical) car possible so I wouldn't have to pass so many potential parking spots. Not in that situation anymore, but I was going crazy circling blocks for 30 minutes at a time mumbling "a GTI would fit in there". Still a great car but if I knew my circumstances were going to shift for the better I would have gone with the S3.
