Spulen all day.
The new PCV from what I've seen/heard doesn't really fix the issue.
If you're a normal driver, all vanilla. You won't need one or notice a difference.
If your go for high performance, HPDE, time attack, whatever you need a proper one.
Spulen and RL both replace the PCV plate n do the work needed to keep the motor running at full speed with high-G forces.
I've had one for 3 years now. The lines are tight, the gasket is well made, and the plate is amazing with additional boost tap ports.
I do empty it, on track at least 2 times a day.
Normal driving, maybe once a week but its rarely full.
I'm FBO, hybrid turbo, pro tuned. Even when I was stock with a Jb4 the problem was the same.
I do use Liqui Moly 5w-40 with m0s2 to help keep things healthy as I put this motor through hell.
When using mobile 1 I would have to empty every 2 sessions on track. With LM I can get 3-5 depending on how hard I push. With the v2 baffles system, I can do a solid 5 sessions before I empty (still not full, just habit) Does that matter? to me yes. Can I explain why with science? No.
I just know the car likes it.
I'll drop this here at the end for you to check out we talk about the Spulen version a bit more.
