I found a copy of the VW service training manual for mechanics/technicians (for tdi common rail engines) on the internet. It goes into detail about the DPF which was interesting to read.
To summarise:
The regen of the DPF is performed in stages:
- warm up
- passive regen
- active regen
- customer initiated regen drive
- service regen
Warm up - this brings the oxidation catalyst and DPF up to operating temperature quickly through an extra injection of fuel after the main injection. Phase is complete when operating temperature is reached.
Passive - soot is continuously burnt without additional intervention when exhaust temperatures range from 350 - 500 degrees C. This is often at normal motorway/A road driving conditions.
Active - when exhaust temperatures are not high enough to effectively burn off soot particles, soot accumulates in the filter. When a specific soot load has been reached, the engine control module will initiate an active regen. Effectively similar process to warm up phase - more fuel burnt to increase exhaust temperature.
Customer initiated - lots of short journeys, where high enough exhaust temperatures are not reached, will cause the filter to reach threshold value. The DPF indicator lamp will come on in the instrument panel. This prompts the driver to perform a regen drive - a short journey at increased speed to ensure high enough exhaust temperatures are reached to burn off the soot in the filter.
Service - if the regen drive is not performed (or successful) the DPF lamp and the glow plug indicator lamp will appear in the instrument panel simultaneously. The text 'check engine - service shop' will also appear. This prompts the driver to take the car to a garage to get it sorted.
There is also a 'Distance Regen' which is a distant dependent regen. The engine control module will initiate an active regen automatically if during the last 466 - 621 miles (750 - 1000 km) no successful regen has taken place. This is an additional safeguard to minimise load condition of the DPF.
It seems there is no visible indication (icon/message) that a regen is taking place, only an indication that one needs to take place. As we all know, there is an audiable indication (the fan running) and a smelly indication (soot burning) but if you're driving, the only indication that a regen is taking place is slightly higher revs at idle.
(I can't guarantee the above info is totally up to date and accurate but it has gone some way to improving my understanding!)
