Failed Thermostat Housing/Coolant Loss Info Gathering
That’s interesting about the cap. My thermostat was replaced this past year and I still smell coolant - although the level hasn’t dropped that I can tell. I guess it could be leaking again, but the smell is mainly near the firewall on the passenger side right around the expansion tank. I don’t see any residue on/around the tank. Is the thermostat/water pump below this area? Maybe I should swap the cap just to see if it solves the issue...
If the level isn't dropping in the overflow tank you don't have a leak.
joeblonewjersey
Metuchen, NJ
Hey idiots who don't work on their own cars....
There is a pressure relief valve on the overflow cap itself. If the valve is failing, vapors escape. That's the coolant you smell under the hood. Eventually the vapor loss adds up to coolant loss.
Read the service manual, it states, when doing coolant pressure test, test the system and ALSO THE CAP. Dealership techs don't read manuals, they don't get paid enough flat-rate time by VW to do so, so they don't know to test the cap.
Look under your coolant bottle, and follow the frame rail. I bet you will see a dirty path that leads to the nose of the vehicle. That's where your coolant is going.
PLEASE, post a picture of the "CAP" and/or its location and/or its part number. Sounds like a stupid request, but nonetheless, it's valuable.
stuntnuts
Maine
Ok after I "look" at it, what am I "looking" for?
Are you serious here? Do you not know what or where your coolant overflow bottle is? Seriously?
It's the little tank in the passengers side of the engine bay that holds the pink Kool-Aid.
Please turn in your Man Card and trade in your VW for a Hyundai. Please and thank you.
Bay Area Smoke Hell
DVP Spektrm, MK4 R32
Can you please calm down and be respectful, or simply leave. Those are the adult choices you can make at this point.
This thread is not for insulting comments and acting like a 12 year old.
This thread is for info gathering on this topic based on observed and verified evidence. You have provided observations, but no verification of said observations and have failed several times to address it when asked.
Thank you.
joeblonewjersey
Metuchen, NJ
Thanks for posting the picture. I was not aware that the cap has a pressure release as well as seal. Given most radiator caps from era past were different, it's different to see it on a plastic bottle of sorts. Thanks for posting. I've got 24k miles on my '16 GTI-S and smell antifreeze. However I have no loss. Mannin' up!
Not true. A MINOR vapor leak out of the cap is enough to cause the smell, but not necessarily enough to drop the coolant level any noticeable amount.
Well if it isn't dropping the level any "noticeable" amount as you said then it's not leaking. Plus you can get air in the system if there's a vapor leak. If the vapor can leak out air can get in.
Hey I've had two Hyundais and I knew where the coolant overflow tank was. ?
joeblonewjersey
Metuchen, NJ
Eh, I'm not stupid, so with that RTFM: https://cartreatments.com/radiator-coolant-overflow-tank/
Pay attention to the end.....stuntnuts
"The coolant tank overflow is non-pressurized on almost all modern vehicles (if the cap is plastic, it’s non-pressurized). That said, as coolant heats up it expands. So if you don’t have a tight seal, coolant can leak out and ultimately cause you to be low on coolant which would cause overheating. Check your coolant level and if you notice the level decreasing, get that cap replaced asap".
So, if it is plastic (it is) and if it needs a "pressure test" (so stated by the 'expert', but actually it is not?), how is it then it can be faulted?
Also, please show me where the "pressure relief valve on the overflow cap itself" exists.
Education is key, that is the purpose of these types of forums.
I know a lot, so if my questions seen stupid to some, excuse my ignorance, we all learn by asking questions.
stuntnuts
Maine
The overflow tank IS pressurized, you fool. If you don't believe me, by all means, go for a nice long drive and park your car. Pop your hood and open your coolant overflow tank cap. You'll feel the pressure.....all 200+ degrees F burning all over your face. I'm serious, please, try it.
Anyways, back to the evidence of a coolant tank cap leak......Look for a trail of dirt that starts below the coolant bottle and travels down to the front of the vehicle, along the frame rail, like in this pic:
I've had two Mk7's and they both demonstrated this. THAT is your vapor leak. Some are worse than others. As you drive, the dampness attracts dirt to the path and when it dries, the dirt remains.
The overflow tank is SUPPOSED to release pressure IF the pressure gets too high, to protect the system. The problem is these caps are releasing pressure at too low of a pressure, intermittently.
Here's the VW Factory service manual describing the PROPER testing procedure, for you idiots who don't believe me:
Bay Area Smoke Hell
Now see? That is HELPFUL, evidence-based, information we can all look at and say, "Oh, hey, cool, we can look at this from another angle now."
Thanks for posting the information.
Two questions:
Was the solution to just replace the reservoir cap? Do you mind editing the post to reflect that solution? Thanks.
zero10
I thought the dirt buildup there was the result of some sealant or something during the manufacturing process... I've got a buttload of dirt and grit stuck on there but it doesn't rub or wash off, it's been there since the car was new. I also have a slowly dropping coolant level so I'll pay closer attention to that spot and see.
