Fahvergnügen
Blade3562
Earth
None
Well I guess it's time I finally place my Mk7 related adventures in one location.
2015 Golf Launch Edition
Silk Blue Metallic
1.8 TSI - CXBA
MQ250 5 Speed - NZA
Modifications:
APR Boost Tap
APR Cast Downpipe
APR Catch Can + PCV Plate
APR Coil Packs
APR High Pressure Fuel Pump
APR Intercooler
APR IS38 Tune
APR Low Pressure Fuel Pump
APR Open Intake
APR Turbo Inlet Pipe
APR Vent Mounted Boost Gauge
Audi A3 Aluminum Subframe
Audi A3 Belly Pan
BC Racing Coilovers W/Extreme Drop
BFI Stage II Engine Mount
BFI Stage II Transmission Mount
Corbeau RRB
DAP Center Exit Exhaust
Denso IKH01-24 Spark Plugs
EBC Brakes BlueStuff DP5059NDX
EBC Brakes BlueStuff DP51518NDX
ECS Extended Stud Conversion
Falken RT660 - 245/40R17
Kuhmo V730 - 245/40R17
Neuspeed Braided Stainless Brake Lines
Neuspeed Front Sway Bar - 25MM
Neuspeed Hi-Flo Turbo Discharge Pipe
Neuspeed Rear Sway Bar Endlinks
Neuspeed Rear Sway Bar - 27MM
Neuspeed RSe05
Neuspeed 340mm 6 Piston Big Brake Kit
Neuspeed 5 Speed Short Shifter
Planted Seat Brackets
Racingline Uprated Torque Arm
South Bend Clutch Stage 3 Endurance Clutch
SBParts Shifter
SuperPro Front Control Arm Bushings
SuperPro Front Sway Bar Endlinks
TrackDecals Magnetic Numbers
TyrolSport Front + Rear Deadset Kit
Volkswagen Alltrack Skid Tray
Volkswagen Center Exit Valence
Volkswagen E-Golf Grill/Badge
Volkswagen E-Golf Hatch Emblem
Volkswagen Golf R Vaccuum Pump
Volkswagen K Revision Coilpacks
Volkswagen GTI PP Rear Brakes
Volkswagen IS38 Turbo
Volkswagen 02J Metal Shift Lever
Volkswagen Polo Blue GT steering wheel
Volkswagen Roof Rack
Volkswagen Satin Silver Mirror Caps
Volkswagen Sequential LED Turn Signals
42DD 2007 Mk5 6 Speed Shifter Bushing Set
42DD VW/Audi Brass Shifter Relay Bushings
2017 Golf Sportwagen S with 4 Motion
Tornado Red
Titan Black Cloth
1.8
TSI
DQ250 6 Speed DSG - QSP
Modifications:
APR Billet Pendulum Arm
APR Boost Tap
APR Coil Packs
APR DSG Tune
APR Electronic Boost Gauge
APR Intercooler
APR IS38 Tune
APR Vent Gauge Pod
BC Racing Coilovers W/Extreme Drop - 10k linear rear
B2BFab Resonator Delete
Continental DWS06 - 245/40R17
Corbeau RRX
EBC Brakes BlueStuff DP52093NDX
HPA Catless Resonated Downpipe
Neuspeed Rear Sway Bar - 25MM
Neuspeed RSe05
Porsche Macan Brake Calipers
Powerflex Race Hybrid Dogbone Insert
RallyArmor Mudflaps
SuperPro Front Control Arms
TuneZilla DSG Tune
TyrolSport Front Deadset Kit
United Motorsport Haldex Tune
Volkswagen Cargo Box by Kamei
Volkswagen Golf Launch Edition Handbrake
Volkswagen Golf Locking Glovebox
Volkswagen Golf Manual Brake Pedal
Volkswagen Golf R High Pressure Fuel Pump
Volkswagen GTI Front Bumper
Volkswagen Mk8R Control Arms
Volkswagen MuddyBuddy Cargo Liner
Volkswagen MuddyBuddy Floor Liner
Volkswagen Polo GT steering wheel
Volkswagen 310x22 Rear Brakes
Volkswagen 345x30 Front Rotors
034Motorsport Rear Shock Mounts
MonkeyMD
Glad you're finally doing a writeup. Nice to see more 1.8 love on here.
How's the new tranny holding up?
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
Liking the thread....watch out on the E-Golf wheels, they are aero designed, so improve air flow...& might be lightweight anyway...
I also see you went GTE front grille.....If there was a way of cleanly removing the blue strip & leaving full chrome & full chrome badge surround..I would...
How's the Polo GT steering wheel?
MonkeyMD
Sucks that it happened, but what an adventure. Can't wait to see where it ends up.
Faceman
Long Island
'17 GSW 4Mo
Although there was an early run that is compatible, your 1.8 will most likely have smaller bearings, not allowing the use of a 2.0 crank. Being that you have a launch Edition, there may be some hope. Good luck.
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
2.0T GLI longblock ordered. 28k miles coming from a '17 GLI. Should be running again by next Wednesday!
build your own, if the "numbers" part is fine.....all matching numbers & spec you want....win win...
tplociniak
NEPA
2017 Alltrack SEL
Really happy I came across your build thread for the information on the brakes on your wagon. I’ve been looking for an upgrade that would keep the same size rotors and allow me to keep my 16” snow setup.
PowerDemon
Richmond, VA
Golf GTI, Camaro ZL1
Bummer to see the old motor blow but happy to see you already got a new one!
If you swap a new motor in your car does the 100k mile bet continue? Or is it null and void now that it blew up the first motor?
