Factory Service Manual
Wrath And Tears
Azusa, CA
17 Sport, 99 E36
Thanks...I got the Carista for the value play. On a tight budget....any scanner you might recommend that is cost effective, easy to use and understand? (I am not super car technical)
Sent from my iPad using Tapatalk
OBDEleven is the best bang for the buck and more focused on VW where as Carista is more general from my understanding. The neighbor at my shop who has a 2016 GTI Autobahn, used Carista to make some changes, like tilting mirror in reverse and stuff like that. So it's not bad, but when you only have the factory code it can be hard. I looked the code up on my diag sites through the shop and there were no results. So it could just be a code that is normally generated depending on the state of the car.
Also if there is no issue, don't worry about the code.
If there is an issue, want to describe it?
jimboski10
Thank you! I had no issues...just pulled the diag from the Carista...that came up along with a Heating and cooling 328964 code (could not find that one anywhere)
