Idk why everyone is getting into “stage 9” clutches and beyond... Stock motor takes about ~400wtq reliably so you most likely won’t go beyond that. So 450-475tq at the crank? So let’s be generous and say you need 500ft lbs of capacity. That’s Ringers stage 3+ clutch at best. I have no idea why you guys think you needs all this clutch capacity... Y’all wildin.
El Bigote answered it a few pages ago imo, he puts its pretty well:
I’ve said it before with clutch ratings and assumed “xxx” holding. That’s not a set in stone number… the manufactures didn’t have a way to specifically pinpoint what xxxx weight PP + xx friction coefficient rated disc can hold exactly hold as driving conditions play a bigger role in this. A stage 3 clutch that’s said to hold say 475 is rated at the flywheel and it’s not accounting for how each car hits that assumed 475… a hybrid car in corn hits max TQ very abrupt and rapid.
if you are set in SMF and soundbend at least get the endurance as the headroom is important on these cars when build with such and strong power band.
I was torn between the SRE and the TTRS... but its been made pretty clear around here they dont even take spicy IS38 tunes well.... im not gonna spend 3 grand and then still have to baby around my clutch..... So this Ringer Racing one seems like the perfect solution, I had stumbled on Rudy's build before and seen him recommending it.
El Bigote's experience with the stage 3 / 4 PP pedal (on the clutchmaster's) being actually decent and similar to the SRE and TTRS, kinda of a great option... Honestly I don't get the hybrid disks, it just makes no sense to have two different materials slipping/clamping and wearing down at different rates.... if i'm going for the ceramic/feramic, might as well all the way.
The lighter PP on the stage 4 also means the thrust bearing is under less stress... dont think is a good idea to have such strong pressure plates.....
This Stage 4 kinda seems the one for me with my IS38....
