I would expect the single 3-4 pulls to look equally as bad then, no? But they look pretty good and are hitting 12 degrees up top.You probably have some mechanical problems. If you have ethanol in the tank, you should be able to hit the numbers your tune is asking for.
Just do select all for measuring blocks please. It's best to record everything.
With good ethanol, try bumping the slider to 91 before raising the boost. That will bring up your timing even when not in boost. It should make the car feel nicer to drive all around. If you just pump the boost the car will feel sluggish unless in boost.
Careful when just randomly mixing like that. Are you using a ethanol calculator?I took a bit of a break logging as I am loving how my car is running at 91oct-22psi with ethanol, needed to go a a few non scientific drives to clear my head.
Having the boost way lower that the file I came from is really enjoyable at 91 on the slider.
Next up I want to log a bit at 93, I’ve done a few short highway drives and I’m seeing occasional single cylinder but need to do way more work.
I also need to see at what point on the slider is best with my shitty 91 California gas so I can rule out the original bad batch convo.
For now I just filled the tank again at about E28 factoring in the 2 gallons left over. Off from work for the week so expect some data (in between the cleaning projects the wifey has planned of course!)
Mostly 3rd and 4th
https://datazap.me/u/knifebright/1-22-91-22?log=0&data=1
Jimmy
what happens if you do 1st through 4th on 91/26?https://datazap.me/u/golfmk7r/log-1611449968?log=0&data=1
First log: 87 Octane/23 PSI. 1st through 4th gear. Really bad KR.
Second: 91 Octane/26 PSI. 4th gear only. Pretty much no KR.
Since I last logged I have filled up from nearly empty (14.2 gallons) with 93 from a different station(BP).
Spark plugs have been changed to brand new NGK RS7 plugs. I also performed a compression test. Each cylinder was right around 160-170. The issue still persists. At this point it has to be false knock, right?
Same thing
Here's one 93/26. https://datazap.me/u/golfmk7r/log-1611498992?log=0&data=1-18-19-20-21-22
Do you have any codes when you scan the OBD?Same thing
Yep, plugs are a step colder. I was always on stock plugs before this.You’re getting more KR with the octane setting lower? I too am lost!
Are those spark plugs a cooler step than your previous ones or were you always running those? I’m currently using stock plugs I changed at 40 and it’s time for a new set so thinking about what I should go with
@ZuMBLe nope no codes at all
