Lth0ms0n
- United Kingdom
- 2013 Golf GTD
So I'm not expert on this, having just started my own MIB1 > MIB2 upgrade, but I recognised the part number and checked out a few parts I have in the house at the moment.Does anyone know what the difference is between the model numbers of this unit? I found one that is Just 5G6-919-605.. i see ones that have a, c at the end of the part number that are non navi.. this one is neither and has a setup button on the upper right as opposed to APP on the other units.. this says h52 also.. is this a brand new ‘21 version?
5G6-919-605 is the part number for the 5.8" display I had for my GTD's Composition Media system. It's a European non-Nav unit with a Setup button where the Nav button would be and a Mute button where the Voice button is:
I happen to have a MIB2 unit here as well, with a 6" display - the part number for it is:
It's also the same around the front - the only difference is that glossy black bezel you see around the display panel on the first one is missing, which is how I imagine the display in your car currently looks..
I will check the part numbering for the 8" matte display that's now in my car later and confirm what they are for you - hopefully it will be of some help. From what I can see here, it looks as if the 'H' number might have something to do with it (I could be wrong) as I know the letters at the end usually signify something to do with the stage of the stage in the life-cycle the car was manufactured. I've seen someone on here saying that the 'C' MIB2 units have less bugs than the 'A' or 'B' ones - you might want to fact-check that though.
I know, for example, that the 'C' MIB2 units are the only ones compatible with the digital cockpit - for example. I don't think there is any issue with compatibility between the lettering and the MIB units themselves - a B display should work with a C unit, for example - but again, I'd confirm that with someone else here before you commit to buying anything.
Having been stuck looking for a new interior trim to fit my 8" display in my GTD, I've sort of arrived at the conclusion that VW intentionally put no sequence in their part numbers to make it harder to figure out what they are. 2 dealers in the UK have both told me this week that they are very anti-retrofit and I feel like this is another effort to, on their part, to make it more difficult!
I could be wrong though...
