Hello guys and thanks you for welcoming me here !
Here you'll find my introduction thread
https://www.golfmk7.com/forums/index.php?threads/hey-from-indian-ocean.369154/
I’m attempting to re-activate ESC on my 2013 (end 2012) MK7 GOLF TDI.
The only fault code I have is « C10C800 Fonction deactivated by adaptation » and the car writes me "ESC OFF" each time I put ignition ON.
Also, the ESC setting won't show up anymore in the car setting on the onboard screen
Please note I do not have the byte 29 on my ABS module as it has been manufactured in end-2012, so my malfunction is not coming from a wrong long-coding.
I use an official ROSS TECH CABLE (HEX NET V2 /3VINs)
History :
A myself-mistake has lead to get my ABS MODULE completely reseted early this year. (long coding 000000....)
I had a look in my ROSS TECH folder on my computer and hopefuly found a complete scan of my car from 2017.
Then I paste the old long coding and the coding has been accepted by the ABS module (I paid attention to re-use the good workshop number etc…).
I then made the basic settings for the various sensors (longitudnal acceleration, vertical, the wheel sensor etc, the brake pedal, etc, of course following different forums and the superb Ross-Tech WiKi
I’ve deleted the fault codes.
All went perfectly and the ABS is back, tire pressure monitoring works well, corner light are back again…
BUT…. IT REMAINS THE FAULT CODE BELOW, and it's the only fault on the car (will post the complete scan just at the end).
Many writes are in French as I'm French but I'll do any translation you'll need. I apologize for my relative english
Adresse 03: Freins ABS (J104) Labels: 5Q0-907-379-IPB-V1.clb
No. pièce Log: 5Q0 907 379 AC Mat: 5Q0 907 379 D
Pièce: ESC H75 0437
Révision: 00000000 No. de série:
Codage: 01FA62A120220A710378060901C42580460450C06080A4F300480024C0
No. Atelier: WSC 01357 011 00200
Jeu de données ASAM: EV_Brake1UDSContiMK100IPB 008020
ROD: EV_Brake1UDSContiMK100IPB_008_VW37.rod
VCID: 7DA707231D7B69DFA1F-8028
1 Code défaut trouvé:
0394 - Arrêt de fonction active
C10C8 00 [137] - -
[The function AYC+TCS or EDS were deactivated by adaption]
Témoin allumé - Confirmé - Testé depuis RàZ mémoire
Capture:
Etat du défaut: 00000001
Priorité du défaut: 2
Fréquence du défaut: 1
Compteur de RAZ: 39
Kilométrage: 133192 km
Date: 2019.11.14
Temps: 17:57:59
ALSO, I can notice by reading advanced identification, there is no VIN registered in my BRAKES MODULE. Is it normal ? How to code it correctly ?
After days and days of investigation, I'm pretty sure to have found the good adaptation channels to modify (2 channels) :
- ABS BRAKES MODULE 03 --> Developer_Function_101 "Anti-Slip Regulation (ASR)" is set on NOT ACTIVATED and there is possibility to change it to ACTIVATED
- ABS BRAKES MODULE 03 --> Developer_Function_102 "ASR and ESP function deactivation" is set on ASR FUNCTION DEACTIVATION and there is possibility to change it to ACTIVATED or ASR AND ESP function deactivation.
SO... We can guess my problem is that the ASR is deactivated.... Well... that's a good thing to kno (and it relates good with the fault code "The function AYC+TCS or EDS were deactivated by adaption"
BUT, my major problem is how to change it ... VCDS don't let me change as it request a security code and no one works ! I've tried 40168 and 201003 and many others...
is there a special code for DEVELOPER ADAPTATIONS ?
Please note I already all the other adaptation channel and basic setting and all seem good.
Your help would be really apreciated as I am driving without ESC from months and months...
As there is a limit of 1 000 words I'll add my full scan in attached file.
Thanks a lot for reading !!!
History :
Pièce: ESC H75 0437
C10C8 00 [137] - -
Capture:
Compteur de RAZ: 39
Date: 2019.11.14
Temps: 17:57:59
