Error: Service Vehicle
BTDUBS
The Interceptor
San Jose CA
Fiat 500 Abarth
Have you find a reliable way to duplicate this every time?
I'm trying to capture a video of it.
Manual mode on the DSG usually on a shift from 1st to 2nd. Problem is that it doesn't show up on any sort of schedule since I always drive my car that way.
eurotrash1
VANCOUVER BC
I have shown a video of the exact error to the dealer, BUT it wasn't my car. I've also provided them with the error message verbatim. Even if I get a video from my car, that will not help to duplicate the concern. VTA knows about the problem and also knows the fix. Lastly, VWOA agreed that asking a customer to obtain a video is bizarre, and in some states it's illegal to operate a handheld device while driving. It is not the customers job to diagnose their own vehicle. This wouldn't be an issue if the engineers would have stored an ECU fault when the error occurs, that way it COULD be seen and diagnosed by the dealer.
So VTA knows the fix but the dealer won't fix it? That makes no sense at all.
vwauditek27
Newbie
NW BURBS
GTI
Warranty dept wants proof that it's occurring on my vehicle before they cover the cost of it.
Wait what????? That makes no sense. If there's a problem with the car and it was duplicated for the tech/manager then they have no basis to not fix it. I would of fixed the car regardless I don't let warranty dictate anything. Car is within 3/36 it's warranty to me!!!
Talon
Began having this issue as well. The error has happened twice over the last few days. Both times the vehicle was warm and the temperature outside was 80°+. Both times it was in manual in 6th gear coasting down a bridge around 70mph. The error popped up for a second, went away, then popped up again. Each time the message was barely up long enough to read.
xtentual
UBRG33K
Atlanta, GA
2008 CW Rabbit
They haven't duplicated the problem on my car, which is why they are requesting a video or picture of the error message.
Which still hasn't happened since I picked up the car from the dealer.
VolkNut
Jackson, MS
Thought I was share the pictures I was able to capture on my 2015 GTI DSG. I'm having the dealer look into this same issue, it's been popping up for a few months but more frequently recently.
Here is my code read too:
Car: Volkswagen Golf
Year: 2015
Engine: CXCA
Mileage: 51951 KM
02 Transmission Control Module
System description: DQ250-6F MQB
Software number: 0D9300041T
Software version: 4511
Hardware number: 02E927770AQ
Hardware version: H52
Serial number: ########
ODX name: EV_TCMDQ250021
Long coding: 0014
Trouble codes:
P072C00 - Stuck in Gear 1
Intermittent
P072B00 - Stuck in Reverse
Intermittent
P174A00 - Partial transm. 1 valve 3 Electrical error
Intermittent
P072600 - Engine Speed Inp.Circ. Range/Performance
Intermittent
P179D00 - Cooling oil valve Electrical error
Intermittent
P173400 - Starter release from the selector lever sensor system
Intermittent
16 Steering Column Electronics
System description: Lenks.Modul
Software number: 5Q0953521P
Software version: 0155
Hardware number: 5Q0953569A
Hardware version: 075
ODX name: EV_SMLSVALEOMQB
Long coding: 0410
Trouble codes:
B116229 - Selector lever park position lock switch Implausible signal
static
Malfunction frequency counter: 8
Date: 2016-04-28 19:09:33
Mileage: 51789 km
Unlearning counter: 179
Unknown ambient data: 86017E000000
Priority: 2
drrck
Zeeland, MI, USA
This is the important part:
static
Mileage: 51789 km
Bad switch and the ECU is freaking the F out.
xtentual
UBRG33K
Atlanta, GA
2008 CW Rabbit
Just got a bunch of error codes in vagcom...
12 Faults Found:
21153 - Gear 1
P072C 00 [002] - Not Selectable
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
21154 - Gear 2
P072D 00 [002] - Not Selectable
Freeze Frame:
21155 - Gear 3
P072E 00 [002] - Not Selectable
Freeze Frame:
21156 - Gear 4
P072F 00 [002] - Not Selectable
Freeze Frame:
21157 - Gear 5
P073A 00 [002] - Not Selectable
Freeze Frame:
21158 - Gear 6
P073B 00 [002] - Not Selectable
Freeze Frame:
21159 - Gear R
P072B 00 [002] - Not Selectable
Freeze Frame:
10731 - Valve 3 in Transmission Part 1
P174A 00 [002] - Electrical malfunction
Freeze Frame:
10732 - Valve 3 in Transmission Part 2
P174E 00 [002] - Electrical malfunction
Freeze Frame:
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
Freeze Frame:
10906 - Cooling Oil Valve
P179D 00 [002] - Electrical Malfunction
Freeze Frame:
10763 - Starter Enable from Selector Lever Sensor System
P1734 00 [002] - -
Freeze Frame:
elizabus
I think I am having this same issue. I have had an error message three times now. The last one was 2 days ago and was the first time it stayed on long enough to read a few words. I have dsg.
I saw "Error: Service" followed by either vehicle or engine. Not positive, but I think it was vehicle. I wasn't able to read the rest of the message before it disappeared.
Same situation, however, started, backed out of driveway, put in drive, and appears within 2-3 blocks leaving the neighborhood at low speeds. Likely always in 2nd gear. It seems very random other than it always being at the beginning of my drive.
The difference with me is that I have already had my shifter replaced due to peeling chrome. The messages all occurred after the shifter replacement.
xtentual
UBRG33K
Atlanta, GA
2008 CW Rabbit
If you have a vagcom cable, keep an eye out for this code. This is the culprit once I saw the below code, I took it to the dealer and they confirmed it was a faulty shifter mechanism.
elizabus
I don't have a vagcom cable, but maybe the dealer will be willing to check for the codes. My service advisor has the same car so he's been fairly helpful with other issues. I'll probably wait and see if it happens again and try to read the whole message. I'll try driving in manual mode more to see if I can trigger it as well.
Are they replacing your shifter? Hopefully that fixes it for you.
