Diggs24
- de plains! de plains!
- 2015 GTI
I have a brand new V1 TPC20 I'll be installing when I gather all the parts needed for MPI. I'm hopeful it will run better than the is38 hybrid I'm currently running...
Why didn't you get version 2 with the ball bearing chra?I have a brand new V1 TPC20 I'll be installing when I gather all the parts needed for MPI. I'm hopeful it will run better than the is38 hybrid I'm currently running...
What's wrong with the Mabo turbo?I have a brand new V1 TPC20 I'll be installing when I gather all the parts needed for MPI. I'm hopeful it will run better than the is38 hybrid I'm currently running...
I bought it from guy locally who never installed it in his GTI. Unit is about a year old. I wasn't really looking for a new turbo, but this one was offered to me at price I couldn't refuse.Why didn't you get version 2 with the ball bearing chra?
I'm not sure there is really anything wrong with the Mabo turbo; but I doubt it will effectively push more than the 28psi I'm currently at (WGDC is around 10-12%). My WG doesn't begin opening until around 4000 rpm in 3rd and boost is 22psi at that point (running e20 on stock fueling). Not sure how much that has to do with not having upgrading fueling vs turbo vs tune.What's wrong with the Mabo turbo?
Do yourself a favor and get that tpc upgraded to v2. That version may actually spool decently. Speaking of versions of TPC20... does anyone have experience running w/a v1 and a v2?I bought it from guy locally who never installed it in his GTI. Unit is about a year old. I wasn't really looking for a new turbo, but this one was offered to me at price I couldn't refuse.
I thought about doing that and reached out to TPC. They wanted more to convert the turbo to the BB version than I paid for the JB version. Seems they also increased the size of the compressor wheel when going to the V2 so it's not just a simple CHRA swap.Do yourself a favor and get that tpc upgraded to v2. That version may actually spool decently. Speaking of versions of TPC20... does anyone have experience running w/a v1 and a v2?
In a few months I'll have experience running version 1 and 2. Getting my version 1 after almost 60,000 miles preemptively rebuilt and converted to the BB version 2. I requested the same size wheels so I could use my EQT dyno tune and not have to get a new tune because of the wheel size change. It costs $500 and includes a new oil feed line. So between the ball bearing and the Trackslag 4 "DP it should spool at approximately 3300 RPM.Do yourself a favor and get that tpc upgraded to v2. That version may actually spool decently. Speaking of versions of TPC20... does anyone have experience running w/a v1 and a v2?
It's only $500 for the DBB update?In a few months I'll have experience running version 1 and 2. Getting my version 1 after almost 60,000 miles preemptively rebuilt and converted to the BB version 2. I requested the same size wheels so I could use my EQT dyno tune and not have to get a new tune because of the wheel size change. It costs $500 and includes a new oil feed line. So between the ball bearing and the Trackslag 4 "DP it should spool at approximately 3300 RPM.
Was. I believe they are raising the price.It's only $500 for the DBB update?
I've had the Trackslag for awhile so it will be a direct comparison to see how much sooner the BB version spools. And while my TPC20 is being converted I'm running an IS38 and yes the Trackslag really helped spool.Curious to hear your experience (sounds like you'll do the DP switch at the same time so it won't be a controlled before/after?). BB is heavily advertised but from my research not always optimal, especially in smaller turbos w/ high rpm.
Weighing adding the 4" dp and bb rebuild to my list, need more info/evidence first. Sounds like 4" dp for IS38 hybrid is a bit of a no-brainer, bb not so sure yet.
