EQT Vortex - MQB Turbo
Probably wiser to just spend the extra $40 up front to get them from FCP, and lifetime warranty replace them every time they wear out.
Plus Rock Auto charges for shipping. Napa usually has them in stock for the same price. FCP least expensive in the long run. Still don't get how FCP can afford that.
daconchslop
South Carolina
FCP has been backordered for a while now on those maybe call and find out if they’ve replenished stock. With FCP you have to buy the replacement part and pay for shipping both ways for the lifetime warranty. Works well with small expensive parts like spark plugs which are inexpensive to ship.
aaronc7
Clovis, NM
I can’t seem to find information online regarding the relative performance difference between the R7437-9 (4654) and R7438-9 (4656).
There isn't... NGK basically has zero marketing info for their racing plugs. They don't even try to convince you how their racing plugs are worth $35 lol.
the 7s are a traditional projected tip vs 8s which are recessed / non projected. You see the non projected style used for true race plugs or high heat applications like big nitrous shots etc. They are great to reduce the chance of pre ignition and overheating, but like everything in life there are tradeoffs..... they will probably foul up faster, not as efficient combustion in normal driving/cold starts etc. So in my mind, I went with the 7s for a daily driver/stock block setup. Once you start to push it so far you have to accept more and more tradeoffs, but I think for typical 400-500 hp build, no reason the 7s won't be just fine. Lots of guys in the 500-600 range running them too. If I was going to track the car regularly I would probably get the 8s... my 2 cents.
I agree. I currently have the 8's and can't tell any difference from the 7's except that I can buy 4 sets of the 7's for what the 8's cost. Needless to say I'll be going back to the 7's.
Acadia18
Rhode Island
2016 GTI SE
Think of how many sales are generated specifically due to their warranty. Just think of the people here alone, buying IS38's from them due to the warranty. Which most don't need to get used. And how many people buy plugs or brake pads from them so they have the warranty, then end up getting rid of the car before they even need to use the warranty?
The promise of a no hassle lifetime warranty (that goes unused) probably generates more in sales for them than they lose due to occasionally swapping a consumable part from warranty.
daconchslop
South Carolina
You are correct. I was thinking of the stock plugs. So the two racing plugs mentioned are just different heat range?
Same heat range. Read Aaron’s post again
MQBS3
Canada
Audi S3
I've had the new non projected tip NGK iridium plugs for a few thousand miles now and they are working great so far
So the R7438-9’s? These or the equivalent Denso IKH-0127 are what EQT advised I run. For reference, this is my daily that I drive about 10k miles/yr.
