Diggs24
- de plains! de plains!
- 2015 GTI
cobb traction control my bet
I thought of that too, but the parameter isn't listed to view. @Ridebjj, enable that logging parameter for next time.cobb traction control my bet
how long would you estimate you are now storing ethanol for...Very strong. Especially first thing in the morning getting onto the freeway when it's only in the 80s and I don't have the ac on yet.
I just bought 2 more 5 gallon gas jugs for stocking up on the corn squeezins. It's 20 miles round trip to get it.
You should check for a boost leak or cat restriction since the WG is shut almost the entire pull, also log targeted boost and relative manifold pressure.Here's another better log from just now. I remembered to shut the AC off before going for it, but still didn't give it enough time for the iats to drop to their potential minimum first. Oh well.
https://datazap.me/u/ridebjj/stage-2-e30-20200716?log=0&data=6-9
Everything seems healthy as far as I can tell. But I'm no expert.
can looking at deltas between the PUT pressure set point and the actually PUT pressure provides that delta data also?You should check for a boost leak or cat restriction since the WG is shut almost the entire pull, also log targeted boost and relative manifold pressure.
https://datazap.me/u/ridebjj/stage-2-e30-20200716?log=0&data=6-9-46
Ethanol sensor ftw.
Yup, not hitting target.can looking at deltas between the PUT pressure set point and the actually PUT pressure provides that delta data also?
Maybe after a E30 tune. Definitely not something I feel comfortable installing myself.
Stoked for this!That 2019 E30 tune is coming. Dropped my car off today for Ed to use as a guinea pig next week. Looking forward to the results.
