EQT E-Tuning Q&A
camel_golf2
Alberta, Canada
7.5 R
The HPFP is operated via the exhaust cam, so its flow is proportional to RPM (at higher RPM it can hold more pressure and flow more fuel than at lower RPM). Having the HPFP max out and drop some pressure in the mid range is not a problem because there is plenty of injection window available at lower RPM's. The ECU just holds the injector open longer to achieve the same desired fuel flow at a lower pressure. At higher RPM, the injection window is much shorter, so holding pressure becomes more critical.
-- Ed
What would you consider “higher rpm”?
Ed @ EQT
GOLFMK7 Official Sponsor
Fairfield, CA
MK8 Golf R
That's pretty cool that the injectors can compensate for lower rail pressure... would have thought the drop in rail pressure would throw everything off...
Not at all the case on modern cars, especially DI. DI is set up to work at a very wide range of rail pressures as the pressure is not nearly as stable as a classic PI only system.
-- Ed
Cliff p.
El Paso, TX
'17 Golf R DSG
The EQT Memorial Day Sale starts May 24th and runs through the 30th!
We at Equilibrium Tuning would like to honor our fallen brothers and sisters in arms, and ask that you take a few minutes this Memorial Day weekend to pay tribute to those that are no longer with us. While you’re out there barbecuing this Memorial Day weekend, take a moment to honor and remember those who gave the ultimate sacrifice for our freedoms. Freedom isn't free, and their selfless service shall be forever remembered.
krs
Las Vegas, NV
MKVIIS R
random question I just thought of today, and couldn’t find a clear answer.
I’m on a E30 tune, do I need to use 91 octane fuel for my blend, or can I use 87 octane for the blend?
Cliff p.
El Paso, TX
'17 Golf R DSG
Strongly recommend you blend with the highest octane available. If that’s 91 in your area, you should use it to blend.
ironicbadger
Raleigh NC
19 MK7.5 R EQT Stg1
I'm tracking my R a lot at the moment. I have an OTS EQT S1 tune and logged a few sessions last time out at VIR with high ambients (85f) on a mechanically 100% stock car. As you might expect by only a few minutes into the session the heat build up was becoming an issue and knock sensors were pulling up to 8 deg of timing - I could feel this in the car throughout the session getting worse, again as you would expect with OTS S1.
Since that event I have upgraded to the IE v2 intercooler and will be out again on track this weekend with even higher ambients. I think I'm looking for something like a Stage 0.5 tune that has a smooth curve and isn't pushing too hard for reliable extended track sessions.
Is this what your custom tune option would be able to achieve for me? A dyno day sounds interesting, what are my options around Raleigh, NC area?
  • datalog18.csv.zip
Ed does some tracking too, so he'll be able to get a custom tune setup for you.
But an oil cooler may still be in your future.
swcrow
7.5 GTI/'29 Ford
OTS tunes leave a lot to be desired, no matter who the tuner is......you need an e-tune
scrllock
MI
where are you getting 8deg from? that's extremely high, especially for a numbed EQT tune. if the tune is set up properly, the timing table will be targeting less due to IATs anyway and it shouldn't show up as knock reduction.
the issue with EQT ots stuff is they run it as spicy as they think they can get away with, even on stage 1 tunes. boost = heat, especially when you're overspinning to 28-29psi. I'd suggest keeping your IS38 in its efficiency range at 25-26psi with less timing up top than a "stage 1" on 93 and then let it eat timing when running ethanol. I've had a calibration like this for a few months now and it's been great for tracking.
ironicbadger
Raleigh NC
19 MK7.5 R EQT Stg1
There's some conversation about it this thread - but it's also in that attached log file from my previous post here.
That's exactly it. I'm not after spicy on track. I'm after consistent! If you've got time to talk me through your calibration (maybe not in this thread) that'd be very handy.
UtahMK7.5
Eagle Mountain, Utah
MK7.5 R
Just placed my Vortex order today and was surprised to see the Cobb and sensors ship 2 hours later! My question is will the Cobb come loaded with the base file if I chose to be tuned through you? Also I'm having a shop install the turbo once it arrives so I assume load the base file and I'm good to drive the car until my remote tuning date.
