You sure about that?
I think when ESC is off it's off.
I am not sure, but I remember hearing that somewhere.
no thats the default TC when everything is on. If you want Cobb TC to activate you need to turn ESC OFF then it will default to your COBB TC settingsCOBB TC is active when everything is on. ESC OFF - coded in VCDS, I spin in second with Indy 500's.
in simple terms if you want to experience COBB TC, you need to turn of ESC cause its more conservative and you will never experience COBB TC in an aggressive mode without doing this.Cobb TC is always active unless you disable it via the AP. When ESC is on, both systems are active, but the stock TC is obviously much more dominant/intrusive. ESC has zero effect on the Cobb system which totally lives in the ECU.
Cobb TC has its limits...it will only pull ign timing to try and control wheelspin. It's probably pulling max timing it can and you're still spinning.
#stage2clubI spin in second with Indy 500's.
That video is brilliant....thank God someone actually tests this stuff with real data. Bravo. Now I get it! I'd love to see the same testing with the various VCDS/OBDEleven mods folks do/swear by to improve these issues.here's a quick video of it in action if you wanna see it working its magic
i wish i knew what exhaust setup this was, sounds great
I swear I’ve seen this comment somewhere before..That video is brilliant....thank God someone who actually tests this stuff with real data. Bravo. Now I get it! I'd love to see the same testing with the various VCDS/OBDEleven mods folks do/swear by to improve these issues.
I love testing man - it's just how things should be.I swear I’ve seen this comment somewhere before..
Thank you - I think this key point is often missed when discussing GTIs.I still get tire spin with a stg 1 tune and 255 RE71Rs.
It's just physics. FWD isn't optimal for launching.
