Hello All
I have 2014 GTI 7. i had an engine failure at highspeed.... Bearing knock on crank. Vw replaced everything internally from a new crank to new pistons and oil pump. so everything internally of the sub assembly.
Now whats currently happening is that i am getting Maximum engine revs 4000 rpm limp mode especially while the engine temperature is at optimal temperature and when i take my revs past 4000 rpm.
this has been going on for some time now. first it was the oil light and they changed all the sensors including the oil cooler.
They Turbo had a crack so they replaced that as well so now the oil light is sorted.
Now it is just this max rpm.
what could it be ? could there be a crack in the block which they had failed to have tested ?
they now removed the camshafts as VW germany has recommended this to be done and the specs to be sent to them
any help or advise or if anybody had this same issue would help.
thank you
thank you
