Engine oil usage on almost new engine
haste
East NC
'21 GTI SE, '15 FiST
I've got a 2021 GTI that I changed the engine oil/filter in at 1900 miles(VW 508 spec 0w-20 and OEM filter). I put 6 quarts in it and the level was perfect on the dipstick. The car doesn't get driven hard as my wife mostly drives it. When I checked the oil level today it was just below the minimum level! The car now has 2790 miles on it, not even 1000 miles since the oil change.
Is this normal? I've NEVER had a car use oil like this. I looked under the car and no leaks, everything is bone dry.
That's excessive even for a new engine. VW will probably say it's normal but I would keep a close
eye on it.
beardedGTI
Louisville, KY
2017 GTI Sport 6mt
Two GTI's in the family, 2017 and 2020, the latter using 0w-20. Both use about a quart of oil between changes. I recall changing the 2020 at around 3k and within 2-3k the low oil light came on.
PRRGG1
The owner's manual reads that 1 QT per 1200 Miles is normal, then adds that "New vehicles may consume more oil over the first 3000 miles".
Your '21 and my '21 have the same mileage and I have lost perhaps a bit more than 1/8 QT so far. The car was driven in 300 Miles from another Dealer and heaven knows how it was treated on the run.
I drive conservatively, but have increasingly put the spurs to it now that the engine is broken in. The factory fill is still in the crankcase. Before I bought it, I checked the engine oil at the Dealership and it was only a tiny bit above the bottom of the dipstick hashmark. The Service Manager looked at it and with a straight face said, "That's where we like to see it". I suppose they like the servicework low oil levels bring.
I bought a quart of VW 508 spec 0w-20 at the Dealership and filled it to where I like to see it -- at the top of the hashmark.
My coolant level has steadily declined, but is still between the marks. This our third VW and they all consumed coolant.
My 18 SE was tuned at 2000 miles and has never used more than 1/2 quart of oil between my 4000 mile change interval.
Escape Hatch
Mk7 GTI
Wow. Gotta break it in how you intend to drive it. I beat on my motor right away when getting it. Now at more than double the horsepower and at 60k miles I don't burn any oil at 5k mile change intervals.
ShadyMF
Upstate NY
2020 GTI 6MT
When you changed and checked the oil, when did you check the level? Just after filling it? After it was warmed up a bit?
I've heard from a few that they burned some oil on the first fill but not after. My MK7 Jetta was similar, but my 2020 GTI hasn't been consuming any 2 fills in, even being tuned 500 miles off the dealer lot.
I'd make sure its at level (After being warmed up, turned off for a few minutes), drive it and check until the next service interval. I doubt VW will do much unless they can show a history of usage anyways.
RobertJG25
Niagara Falls, ON
2019 VW Golf 1.4 TSI
Came here to say this, if you check just after filling and then again after running the engine, it will be lower because oil has made its way into the filter.
hans611
Lost
Miami
'16 Golf R 6MT
Its weird a few people with MK7 still report moderate to heavy oil usage, half a quart or more is a decent amount imo...
My old MK5 with the FSI used to burn up to a quart at times after the 5k... but those would always burn oil....
.....it was entirely how hard it was driven/on boost.... but it would always burn some....
With my MK7 I got one that apparently burns no oil, I got it with 19k mi and went the full 10k mi actually for that first interval.... didn't drop at all..
I'm doing 6-7k mi internals now and still nothing....
One of the reasons for doing shorter internals, apart that I started driving less, even before the virus, was how little oil it would burn...
With the other car I would "replenish" the oil sort of speaking over its interval as the little MK5 burned it...
Here its the same nasty oil getting diluted with fuel, etc and not going anywhere....
edit: Back with the MK5s (FSI and TFSI) VWOA would consider 1 quart per 1,000 mi acceptable.. I guess that still applies today. 0.5q every 5k doesn't sound so bad now....
I would say now the MK7s they tend not to burn and the few that do, may burn a decent but still reasonable amount...
Back then they all burned oil.. either a bit or a shit ton...
Its weird, I wonder if its one thing, like say the turbo bearing or multiple things like + the piston rings / blow by, etc... Some may just be an unnoticed leak....
beardedGTI
Louisville, KY
2017 GTI Sport 6mt
I hypothesize that it has less to do with mechanical tolerances and more to do with driving styles. Our family lives in the city making frequent very short trips with lots of stop and go. Pretty much the worse case for gas vehicles. Environmental factors like temp and elevation would play a role too.
goodvibes
IL
If you drive more spirited than she does, this may be the time to switch vehicles for a bit. Use some engine braking and harder acceleration for a while and see if you can get the rings to seat a bit better.
hans611
Lost
Miami
'16 Golf R 6MT
I went back to the old threads and I had it wrong, it wasnt 0.1q per 1,000mi that was acceptable, it was 1q per 1k... so 0.5q per 5k is probably fine...
I would say I'm driving the Mk7 just as hard or harder, and in the same conditions, even with the same oil....
I also have a friend in this area, similar conditions, drives even harder, with a 2007 MK5 (FSI too) but would consume much less than my old MK5.
beardedGTI
Louisville, KY
2017 GTI Sport 6mt
If your location is accurate our conditions are definitely not the same.
Jovian
Sunnyvale, CA
2016 VW GTI
My MK5 FSI also burned a lot, 2qt every 5k miles. Didnt seem to matter much how I drove it. I just did a lot of oil changes and checked it often. Traded it in at 155k miles.
My MK7 doesnt burn any measurable amount of oil even at 110k miles. I have owned it since new.
