Dog Dad Wagon
- Go Birds
- 16 Touareg TDI
This video has been shared previously and illustrates why you want to connect the upper and lower mounts. I've seen the APR dogbone bend at the lower mounting attaching point when only lower inserts are used. The following link has a lot of good information regarding the inserts and why you want something that fills the voids in the upper and lower mounts. https://store.034motorsport.com/034...n-mk75-golf-golf-r-gti-jetta-7-speed-dsg.html.
Based on the recommendation of one of my friends I went ahead and modified my powerflex hybrid mount to accept the 034 upper insert. And I should also note that the ECS dogbone is not a direct fit for the powerflex hybrid puck (had to machine down the aluminum cup thing that comes with the insert so it would fit in the dogbone).
I did the APR Lower Steel Insert + APR Pendulum bar and 034 Upper insert with stock uppers and it made a 5-10% increase in NVH, and it’s really zero N or H, only Vibrations at idle speeds in 1st and 2nd.
I am looking forward to getting the BFI Stage 1’s. Had them on my last car along with APR Pendulum bar and power flex insert. The NVH from the mounts was nonexistent Besides, like others say, a better exhaust note.
