engine knock
plastermaster
Gualala
Just wanted to get some thoughts and others experience if any.
2018 standard Golf TSI.
When I am driving up a hills in areas at low speeds like 15-20 MPH, (due to speed limit in the area) my automatic transmission is lazy about downshifting, and I will get some engine knock. I use my paddle shifters to drop down a gear otherwise the engine will be running < 1500 rpm. I had the shop check it out last time I had it in for some work but they couldn't get it to do as I am describing. 2018 standard Golf TSI. It will also do this around 25 mph when the auto wants to be in 3rd up a hill. This isn't one off behavior for my car it is very consistent. It is possible that I am mistaking knock for some other vibration, but I'm pretty sure it is knocking based on my experience with aircooled VWs running too high compression and bad gas.
I am interested in getting an APR ECU tune, but concerned that adding boost will exacerbate the problem if I have an issue with the auto transmission not wanting to downshift properly. From what I know the APR tune only changes boost.
Look forward to your thoughts!
YamR1rider
Tampa, FL
2017 GTI Sport DSG
Is it throwing the EPC light or other codes to say it's knocking? Otherwise I'd suggest what you are feeling is the engine just lugging a bit if on light throttle at a gear change threshold.
Have the 87 octane APR tune on daughter's 1.8, I'd highly recommend it.
DerHase
Hampton Roads, VA
2019 GTI Rabbit
Even when I was seeing nearly 20 deg of knock on all cylinders on track - I never heard anything audibly. These cars don't have audible marbles-in-a-bag type sound like some other cars do when knocking (like Nissan 3.5s or Hyundia 2.4s tend to do).
I agree with the above it is probably just hearing stuff rattle due to low RPM low load. Especially if you're not logging knock or setting DTCs etc.
plastermaster
Gualala
Thanks for the replies. I definitely am not getting the EPC light, but not sure if my car is equipped with one, and I don't have a way of reading codes. Good to know it probably is just a rattle. As for codes, if I am getting some engine knock, would it be recorded and verifiable with a scanner?
DerHase
Hampton Roads, VA
2019 GTI Rabbit
Only if you're watching live data. To be clear: the knock sensors on stock engines are super sensitive. They are meant to be very conservative and retard a bit of timing when necessary. A little here and there is absolutely zero problem. If you see > 3.0 deg or so then there might be an issue worth exploring (or bad fuel, etc). Easiest way to tell if it's "false" knock is to throw a gallon of E85 in the tank right before filling up with 93. If it's still registering knock with that then there's probably a mechanical rattling (heat shield, exhaust, etc) that's triggering the sensors to pull timing.
I'm 99% none of that is necessary, just leaving for others if they happen to see this in a search, etc.
odessa.filez
Roswell, GA
2016 GSW 1.8tsi auto
My 1.8 auto sucks on hills in D, especially in the summer. Until it warms up, I'm driving in S.
Likewise, downshifts are sometimes clunky in the heat.
I would get a pedal box. I bought a Burger Motorsports version used for slightly more than 100.
Used JB4 is cheap as well, but would need higher octane fillups. As noted, there is an 87 octane tune out there if that's your typical octane.
YamR1rider
Tampa, FL
2017 GTI Sport DSG
Totally agree...some more than others. A big part of the reason for putting the APR tune on daughters 145k miles car was that after I'd replaced all plugs, coilpacks, injectors and done a carbon cleaning, very occasionally and randomly when the car was lukewarm and lugging along in D under light throttle, it would shudder and trip the EPC light. Turn on/off, all good to go. Code being thrown was 'cylinder pressure too high' followed with hide cylinder (on any one of the four). After a lot of researching around, it transpired that some 2015/16 1.8 MQB cars had experienced the same and a software fix was available. I also read that the APR tune also took care of the false-knock issue, so I went that route and voila, issue is now long gone....and due to the tune the car drives way better in an OEM+ way than stock as a bonus :)
Again, OP as they guys above also mentioned if your car isn't throwing codes or or EPC light you've got nothing to worry about - just normal behavior of the 09G trans. If you've a mind to tune, go for it. I believe APR currently has a sale on too.
plastermaster
Gualala
Thanks all for putting me at ease with the knocking. I'm looking forward to the tune. I'm not seeing a sale currently, but the price of tuning for our cars is quite reasonable. Porsche is twice as much for a much smaller % increase in power.
@ odessa.filez, Interesting idea about the peddle box. Maybe I'm just used to what I have but my throttle response seems fine, other than when I confuse it with my left foot braking. I will observe it carefully the next time I drive to see if there is room for improvement.
