Engine bay rattle
noluck289
New Jersey
2017 Mk7 gti
Decelerating at 4k rpm or above I get this really bad rattle from what I can tell the passenger side of the engine bay. The noise is almost like a disk rattling or something and only happens when the revs are dropping and never on throttle. Was wondering if anyone has this issue or has any ideas how I could solve it.
noluck289
New Jersey
2017 Mk7 gti
start inspecting DP placement, heat shields, vbands, etc... if nothing shove something up in the frame where the fuel rail is and see if that helps.
Thanks for the reply. Im thinking it’s something with the heat shields too but i’m gonna have to look. Will try that fuel rail thing as well.
Daks
Toronto
GTI PP
Yes there is a spot on the driver side where there is a lot of play cause it doesn’t bolt down. I’ve tried sticking something in between there and the noise is still there but will try again.
Thick piece of foam is what I used.
JerseyDrew77
Virginia & NC
2016 TR GTI S 6MT
That intake also rattles.
It only rattles and doesn't bolt down due to install error.
Daks
Toronto
GTI PP
