Dog Dad Wagon
- Go Birds
- 16 Touareg TDI
The studs on the stocks cracked when i tried to remove tge nuts. So there's that.
replace with new stocks
Too late, Moogs on the way.replace with new stocks
Does powerflex make them?
As others have said, I only hear great things about Moog. Hit them with some enamel paint if you wanna prevent surface rusting.
Got Moog endlinks in the mail. Greased them. Are they supposed to be very stiff?
Yeah they feel really stiff when they're out of the box in your hands. You should still be able to move the joint though, even if it's only a little bit.
As long as you greased them they should be good to go.
Yeah, i could move the joint, albeit with quite a bit of effort.
Lowered?Also, OEM Endlinks are perfectly sufficient, and make no noise!
I have been through it all with endlinks and have settled on reverting to stock, after reading that Jim has been on stocks for like 80K miles w/ no noise or issues
Installer error definitely possible. Zero issues running them on the superpro RSB. Can you try to warranty?
Nah, stock AT suspensionLowered?
