If you switch the tech package to the one noted as not supported by mk7r hardware, you'll see that we don't have the latest engineering by any means - the hardware in the mk7r's forward lighting is several years old now. The missing hardware won't be available to participate in the protocol exchange and a bus signal error will set, disabling the advanced system (not the lights, just the tech). I haven't tried every combo, but I'm reasonably certain that all but that one are supported by the hardware present.
These are trick units, just not the latest. Still at least ten times good enough to implement NA standards, though.
I thought this would be apparent from the comments included with the video and vw links. I'm sorry if it's still confusing.
happy trails....
ICmaker
so i have enable HBA using th eOBD app a few months back does that mean i can just continue to these steps
(2016 & 2017) (Select a hardware supported Technology Package)
09 - Central Electrics – Coding (AFS, FLA, Fernlicht (GLW, MDF) is not supported)
Select: Erweiterte_Fernlichtsteuerung (Advanced High Beam Control)
Change to: AFS, FLA, Fernlicht ueber AFS (default = AFS, FLA, BCM-Fernlicht)
Execute (green check)
(2016 & 2017) (Remove NAR Restrictions)
55 – Headlight Regulation – Coding
Select: market
Change to: ece (Default = nar)
Select: City light (enable AFS patterns)
Change to: enabled (Default = not enabled)
Select: rain_light
Change to : enabled (Default = not enabled)
Select: all_weather_light
Change to : enabled ( Default = not enabled)
55 – Headlight Regulation – Basic Settings (Run & Acknowledge Setup)
Select: Basic headlamp setting
Select: Acknowledge basic setting
or has it already done some of these as well ?
