This has happened twice to me, but within about afew days of each other. After a couple of minutes of starting the engine, or could be just powering it on, i am not sure as i haven't tried that, but i find my rear window just opens. all the way. I can't even close it straight away either from the drivers side. Clearly an electrical fault, i assume the switch. But which? the door of the window or the drivers door cluster?
Just curious if anyone has had a similar problem. I am initially going to look at the rear passenger door switch first when i get chance.
