ECS Tuning
- Wadsworth, OH
Excited and don't want to read click HERE to view the new ECS Stage 2 Performance Clutch and Lightweight flywheel combo
TOTAL COMBINED WEIGHTS - OEM - 41.03lbs / ECS 31.15lbs
After nearly half a decade of in-house engineering, testing and retesting of multiple iterations of prototypes, across a wide range of Stage 2 tuned vehicles, we are excited to give you our best clutch kit yet! Our kit is engineered to reliably hold 400 ft/lbs of crank torque and feature specifically selected components for performance and daily driving styles while retaining easy commuting characteristics and enthusiast-minded control and feedback!
ECS Stage 2 Performance Clutch and Lightweight Flywheel
Are you looking to make more power from your VW but afraid of melting your factory clutch with the increase in power? All too often most tunes near Stage 2 power levels will destroy your clutch the moment you even think about getting into the boost. The unfortunate consequence used to be an expensive clutch upgrade that would break the bank and sacrifice the ease of driveability. Well, at ECS we felt the same pain and decided to carry on our legacy of designing and creating top quality, easy to drive, affordable performance clutch and flywheel kits, now available for your Volkswagen MK5/MK6/MK7 2.0T platform (or similar) 6 speed vehicles.
PART DESIGN
CLUTCH DISC
240mm Full face, high performance organic friction material with integrated copper for enhanced heat dissipation and a long component life
OE-like marcel friction backing plate design for smooth engagement with dual stage damping springs to reduce gear noise, driveline chatter, and for smooth engagement
PRESSURE PLATE
Increased clamp force over OEM, rated at 1,685lbs of pressure
THROWOUT BEARING
Genuine OEM for ease of install and reliable operation
CLUTCH ALIGNMENT TOOL
VW 2.0T Specific Design, made for perfect fitment into crank bore
Perfect clutch disc spline and size, easy removal with pull tab
PLEASE NOTE: Not all aftermarket clutch kits include this proper alignment tool! We ensured you receive the proper tool for trouble-free installation!
FLYWHEEL
18.85 lb. single mass lightweight flywheel (32% reduction from stock)
Specifically selected weight for ideal combination between daily and sporty driving style; faster revving for quicker gear changes and less rev-hang
Precision CNC machined from Forged 4140-HT Chromoly Steel
Homogeneous material properties promotes even wear and has superior resistance to warpage and chatter
Heat Treated to 28-32 HRC for improved wear resistance
High precision balanced for exceptionally smooth operation at high rpm
Designed and tested by a 3rd party lab to meet SFI 1.1 specification for added quality assurance.
SFI 1.1 specifies the minimum requirements for material strength and quality, as well as a 3rd party lab spin test to 150% of redline for 1 hour to ensure integrity of material and design.
Black Oxide coated for corrosion resistance
PART DESIGN
CLUTCH DISC
PRESSURE PLATE
THROWOUT BEARING
FLYWHEEL
