tigeo
- Richmond, VA area
Also - folks don't seem to understand that unless you are under power/boost, an aftermarket IC will look basically like a stock IC....
Mine is around 170* also with the AMS stock location IC. But when it's 118* ambient and you sit at a light the temperature rockets up.Christ. Is this on the stock intercooler
Yup… just like when cruising and pushing 1-3 psi won’t show shit either, yet it’s still commonly referred to as a means of IC performance measurements.Also - folks don't seem to understand that unless you are under power/boost, an aftermarket IC will look basically like a stock IC....
You want gnarly come to Phoenix. Highs around 117-118* for the last week.
I would stick with those temperatures too. And thankfully it's a dry heat (low humidity) or it wouldn't be livable. It's barely liveable with low humidity.Nah, I'm all set. Fuck that "It's a dry heat!" shit. I'll stick with my beautiful 80 degree days.
the dry heat doesn't sound all that bad when you're outside shoveling snow at 7amNah, I'm all set. Fuck that "It's a dry heat!" shit. I'll stick with my beautiful 80 degree days.
Ask George at BMS. He's very helpful.Well I didnt listen to Chrismk77 and I tried to get a log with the JB4 and im pretty sure on the second pull below the car went into limp mode. Threw a bunch of codes; had a flashing CEL and EPC light on. I turned the car off and then back on after I took a screen shot of the codes and it drove just fine. It was 90 out and on the second log you can see temps within 10 degrees of ambient, though I didn't get to finish 3rd gear for the pull. Ill have to get a clean pull with and log with the access port tomorrow.
I was going to keep the jb4 for the guages and possibly for a w/m controller in the future, but it just doesn't seem worth the risk for it to keep switching maps automatically. I don't know why it is doing that. I am definatey going to keep it unplugged and I may just sell it on here seeing that I dont have much use for it if it is going to keep acting like this.
https://datazap.me/u/vwgtilife/ac?log=0&data=1-4
https://datazap.me/u/vwgtilife/log-1624240681?log=0&data=1-4
I don't think it's necessary, I didn't do it for my ic, but if you wanted to run compressed air thru it to blow it out I don't see anything wrong with thatI'll be installing a majesty IC sometime soon and I was wondering if it would be a good idea to clean out the inside of the IC?
What size clamps does it use?Mine was clean. You will want some better clamps unless they now ship with proper which I doubt. Just disconnect existing I/C hoses and cut 2 1.5” long pieces stuff them in the kits bigger silicone hoses with gasket sealer …It also helps to warm hoses in sun before installing for flexibility.. These are the clamps that work the best.
Buy a 2.25" OD silicone coupler that is about 4-6" long and cut in half. One piece for each side.What size clamps does it use?
Looking at the picture in the add it looks like they might include a coupling that can be used as a spacer. I'll have to see when it gets here. I'd prefer not to cut any of the stock parts just in case I need to put it back.
Fit inside the new tube and then onto the stock intercooler.
I used the clamps that came with mine and they worked fine.
You don’t need to buy anything just the 2- 3.25 T clamp that’s it if it comes with coupling’s and you will want to secure with extra hardware aka screws or nuts bolts. It’s clearly marked 325T and if you read summits description it tells you circumference.What size clamps does it use?
