Got aligned after swapping to different springs and camber puck. Just wanted some feedback on my current specs. A little confused on the variance of caster and why I wasn't able to achieve almost equal camber in the front since I've got a Tyrolsport deadset kit in. I pushed the strut towards the engine as far as I could whilst tightening the 3 top bolts and loosened the ball joint nuts and pulled the rotor as far as I could. Car was pulling slightly to the right, but could've been the crown in the road as the car did track straight on the highway on my way home. Wheel is slightly crooked to the left, but it's never been dead straight from day 1. Shop told me they'd re-do the alignment if I'm not happy. Curious on what I can do to even out the camber and what can be done to center the steering wheel, I read up on the steering angle sensor reset but not sure if that will help, or I need to sit in the car with a 0 reading and then have him adjust toe.
Current setup with Koni Yellow, Eibach Pro-Kit springs and Eurosport Camber Kit:
Front:
Caster 7.55° / 7.18°
Camber -1.99° / -1.72°
Toe 0.01° / 0.02°
Rear:
Camber -1.70° / -1.69°
Toe 0.03° / 0.03°
Previous setup with Koni Yellow, VWR springs and SuperPro camber plates:
Front:
Caster 7.44° / 7.17°
Camber -2.16° / -2.14°
Toe 0.01° / 0.00°
Rear:
Camber -1.77° / -1.72°
Toe 0.05° / 0.06°
Front:
Toe 0.01° / 0.02°
Rear:
Toe 0.03° / 0.03°
Front:
Toe 0.01° / 0.00°
Rear:
Toe 0.05° / 0.06°
