yeahforbes
- NJ
- 2017 Golf R DSG
Hey all, I've been EQT tuned for 700 miles now (ECU+TCU), and it's great except for a DSG issue I've been having. I want to be very careful not to blame the tune if it's unrelated, but I had absolutely no DSG issues the entire time I've owned the vehicle until tuning, and then the issues started immediately, day 1, before I even had an EQT DSG file and had to flash the Cobb OEM+ file. I have driven exclusively DSG cars since 2014 and I am very aware of its quirks, so please don't take this as a generic "why are DSGs slow sometimes" kind of question.
I'm not sure what the proper terminology is (false neutral, clutch slippage, etc.) but hopefully this log will help us figure it out. Whatever it is, it's not just a delay as you might encounter when the DSG guessed wrong and pre-selected a different gear than is being requested. It has happened about a dozen times so far, in just 700 miles and each time I feel like it's dying a little more.
I finally caught it while logging. Check out this log on datazap where you'll see that I have zoomed into approximately 290 sec to 310 sec. The scenario is that I'm cruising in top gear, and I let off the gas completely for a downhill. It's a steep downhill followed by a curve so engine braking is called for. Here are the points of interest, with ZERO throttle throughout each one:
296.11 - manual downshift 6>5, rpm blips from 1888 to 2336 over 0.26 sec = OK
296.42 - manual downshift 5>4, rpm blips from 2336 to 3040 over 0.34 sec = OK
297.14 - manual downshift 4>3, rpm flounders from 2976 to 3616 over 1.78 sec = BAD
That 1.78 second downshift is the problem which has happened about a dozen times. Most of the time it's actually when going down to 2nd, but this time it was when going down to 3rd. One time it even happened going down to 1st (but I don't make a habit of aggressive shifts into 1st, of course) and I think it even happened in 4th one time. The point is, it's not associated with a single gear.
In this case, I was totally off the gas so I only noticed due to the lack of immediate engine braking (and seeing the tach reveal the sluggish blip). In other cases, I get on the throttle when it's happening and it just revs almost as freely as if I was in neutral -- a scary moment.
Currently around 31k. Is this the sort of thing that a DSG service could clear up? I did the DSG Default Settings after about half of them, and it didn't help. I can try the other calibrations after I obtain a repair manual.
