Dsg right hand paddle
Avanti
UK
(+) to shift up , the left hand one has a (-) on it to shift down, and if you hold it it for a second or so, then OFF, switches the anual mode OFF, so you are back to good old auto shifting.
Abbott Martin
Mid-South
GTI Performance 2dr
It makes S mode useable.
Abbott Martin
Mid-South
GTI Performance 2dr
What I do is put it in S, when it starts to rev too high just hold the right paddle, it upshifts and then goes back to S mode.
Mark V1
Herts, UK
I found this video about DSG from a older GTI model.. I would think it should be the same.
No its different now - on the earlier cars to go from Normal auto (D) to Sport mode (S) you needed to press the release button on the shift stick and pull it back in to the Sport detent. On the Mk.7 there is no need to press the release button and the shift lever is spring-loaded defaulting to D/S so to select S you need only pull it back and allow it to spring back forward in to D/S. In other words D and S are in the same location and you just toggle between them
This is a huge improvement and makes S selection so much simpler - particularly good for people who, like me, use as for engine braking when approaching junctions etc.
Abbott Martin
Mid-South
GTI Performance 2dr
The new system is much better as I also swap between sport and D often.
