Why?
You will have almost zero lateral space between the edge of the brake and the start of the clutch pedal. You are going to hit the brake going for the clutch and get rear ended by some idiot tailgating, staring at the mk7 facebook group page or using taptalk here.
APR may have made a mod just for you...
DSG pedal system.
Mk7 R...3 pedals
MODS: APR software/034 engine/trans/dog bone inserts/fr&rr strut mounts/rear camber arms/rear toe links/rear subframe inserts/Superpro Sways/moog endlinks/Audi Al subframe/tyrolsport subframe collars/ MK3 TT control arms & balljoints/RS3 brake ducts (modded for TT arms)/AWE resonated DP/Audi S3 Res Delete/AFe dryflow filter/Unitronic TIP & charge pipes/Revo intercooler/HStuning RSR clutch/ECS clutch line with bleeder block restrictor/return spring removal/42 Draft design shifter bushings/s3 euro shifter/Eurocode fr&rr chassis bars/-2.5deg camber front, -1.7deg rear, Zero toe on all 4 corners/Mk2 TTRS front brake calipers with girodisc 2piece 370mm rotors/Neuspeed RSe11s 18X8in, 245/40/18 PS4Ss...Stock DCC shocks/springs...
Upgrade your tires, then your pads and fluid.... b4 you post about getting a BBK...
