yakboyslim
No need to drive the car for it, just need to have the car on (not even engine running). I'm sure things are slightly different with VCDS, but OBDeleven instructions might be close enough.
- Figure out what version gateway you have (should start with 5Q0 or 3Q0). This should be in the module info somewhere.
- Then go into the gateway module and look at live data.
- The live data parameter we want says something to the effect of "damping mode"
- While watching this data you can cycle through different driving modes using the button or the radio.
Driving mode selected What you should get What you will get if DSC and Gateway aren't getting along. Comfort 1 2 Normal 2 2 Sport/Race 3 3 Individual 1, 2 or 3 2
This is how you would go about logging it to see if you have the problem. If you have it PLEASE contact DSC. They have been very slow to respond to my stuff - totally unhelpful on this issue. Partially I think it is because they keep asking me where I bought my unit (like it's fine to blow off the guy who bought it used, even if he is trying to help you understand the problem...)
I do have VCDS so I can log with either to test for comfort mode. I would love to use the program to help with tuning because as of right now I’m thinking of reverting back to the stock controller because I didn’t mind the B6’s with the stock controller but I picked up the DSC controller in an effort to get more out of my setup. So I’m definitely willing to try some tuning before I give up.
Absolutely. I tried to write a bit of a wiki on the Github for the tuning program I wrote. If you want to take a look at that, especially the part about converting your .pdts file (you have to use a google spreadsheet I wrote to convert your current .pdts to a .csv, after that you could always just use the YakTUNE program to make baselines). Any questions though feel free to post here or PM.
Two easy changes I would recommend trying right off the bat if the stock DCC feels better are:
- Zero out your velocity table. Just make it zero for all the compression/rebound speeds at all four corners. This table is tuned - fairly well actually - for the stock Monroe shocks, might not be great with the B6.
- Zero out the entire acceleration table except for the launch portion (zero the parts based on pedal position). DSC even recommends not to use this table now that they have introduced the launch control tables. It appears they removed the function that would fade the influence of this, so now rather than being a preemptive factor, it just makes the car too stiff whenever the pedal is pressed.
