Driver Steering Recommendation disable
Navi
BK/NYC/Hamptons
Those who are running DSR disabled, have you encountered any vcds codes from associated modules? I disabled it and keep getting the following code:
Address 03: ABS Brakes Labels: 5Q0-907-379-ESP-V1.clb
Control Module Part Number: 5Q0 614 517 AF HW: 5Q0 614 517 AF
Component and/or Version: ESC H62 0398
Software Coding: 01FA6BA1542209714079020241C36880D62A90024082163600430051C00603
Work Shop Code: WSC 12345 123 61029
ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019 (VW37)
ROD: EV_Brake1UDSContiMK100ESP_035.rod
VCID: 75B4EB5ED54E7A5FBD3-8021
Fault Codes have been Erased
1 Fault Found:
8277 - Databus
U1122 00 [009] - Implausible Message
[FCAN: EPS_DSR_Status signal is invalid]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 130
Date: 2018.11.24
Time: 10:02:12
When I clear the code, it immediately comes back. When I reactivate DSR and clear the code, it goes away and never comes back. So I assume it has something to do with ABS brake module, ESP and DSR not playing well together when it is disabled. I have seen a couple people disable DSR on the forum, but no one mentions this? Anyone else seeing this code?
Thanks.
yirayira
Chicago, IL
2015 GTI SE
Are these faults triggering a dash light?
PLF8593
Philly
19 Alltrack 6MT
I have not scanned my car since activating this tweak so I don't know if there's a soft code thrown. But note my car is a 2015, and it's pretty clear there's lots of differences on the OBD2 end of things between model years. I'll get back soon (next week).
yirayira
Chicago, IL
2015 GTI SE
No faults on my car and the ABS still does its thing. Are you using the older Micro-CAN cable?
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
I'll have a look at mine...as I've only recently done the change & not re-scanned since...
yirayira
Chicago, IL
2015 GTI SE
no, i'm using the current cable that rosstech sells at the moment. That's weird. I wonder if it has to do with 2015 vs different years...
2017 has been odd year out, 15 and 16 have been the same for me in VCDS
mrd8cd
St. Louis, MO
so anyone with a 2017 model year try this?
I'm going to try disabling DSR this weekend using OBDEleven, as I'm experiencing the "notchy" steering issue currently. I'll report back with my findings.
Navi
BK/NYC/Hamptons
yeah please let me know it it starts throwing the code i mentioned. I have noticed the electric steering intervening more and more now that I focus on it. I wish I could turn this off and leave it off lol
mrd8cd
St. Louis, MO
I just tried disabling the DSR using OBDEleven and after going into 44 electric steering assist module > coding > long coding > byte 0 > bit 4, it was already unchecked. So I assume this means I’ve had DSR disabled the entire time I’ve had the car?
