Driver Steering Recommendation disable
Navi
BK/NYC/Hamptons
Those who are running DSR disabled, have you encountered any vcds codes from associated modules? I disabled it and keep getting the following code:
Address 03: ABS Brakes Labels: 5Q0-907-379-ESP-V1.clb
Control Module Part Number: 5Q0 614 517 AF HW: 5Q0 614 517 AF
Component and/or Version: ESC H62 0398
Software Coding: 01FA6BA1542209714079020241C36880D62A90024082163600430051C00603
Work Shop Code: WSC 12345 123 61029
ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019 (VW37)
ROD: EV_Brake1UDSContiMK100ESP_035.rod
VCID: 75B4EB5ED54E7A5FBD3-8021
Fault Codes have been Erased
1 Fault Found:
8277 - Databus
U1122 00 [009] - Implausible Message
[FCAN: EPS_DSR_Status signal is invalid]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 130
Date: 2018.11.24
Time: 10:02:12
When I clear the code, it immediately comes back. When I reactivate DSR and clear the code, it goes away and never comes back. So I assume it has something to do with ABS brake module, ESP and DSR not playing well together when it is disabled. I have seen a couple people disable DSR on the forum, but no one mentions this? Anyone else seeing this code?
Thanks.
Navi
BK/NYC/Hamptons
No, no dash light. I only noticed because I was scanning for an EPC light for an over boost. Makes me think the abs module needs that activated though.
PLF8593
I have not scanned my car since activating this tweak so I don't know if there's a soft code thrown. But note my car is a 2015, and it's pretty clear there's lots of differences on the OBD2 end of things between model years. I'll get back soon (next week).
Navi
BK/NYC/Hamptons
no, i'm using the current cable that rosstech sells at the moment. That's weird. I wonder if it has to do with 2015 vs different years...
Navi
BK/NYC/Hamptons
yeah please let me know it it starts throwing the code i mentioned. I have noticed the electric steering intervening more and more now that I focus on it. I wish I could turn this off and leave it off lol
mrd8cd
St. Louis, MO
I just tried disabling the DSR using OBDEleven and after going into 44 electric steering assist module > coding > long coding > byte 0 > bit 4, it was already unchecked. So I assume this means I’ve had DSR disabled the entire time I’ve had the car?
mrd8cd
St. Louis, MO
Lol wtf. More confusion to add to the mix. When you run a scan of your car, do any codes pop up?
No codes other than the usual suspects: satellite radio tuner not active, function restriction due to communications interruption, low key fob battery voltage. Otherwise I'm code free. Occasionally I'll have the oxygen sensor 2 "delayed response" that will trigger a CEL, but that's only because I'm running a downpipe without a tune. I wonder if DSR is only activated from the factory if your car has driver assists, such as lane keep/departure, radar cruise control, etc. :confused:
Navi
BK/NYC/Hamptons
My car doesn't have those features but still has DSR activated. Very weird. Side note - do you know what the function restriction due to communications interruption is? I have that also. Seems to be related to the telecommunications module?
mrd8cd
St. Louis, MO
I honestly have no idea what it is. It appears to be a passive fault, so no CEL triggered, and it doesn't appear to affect the car in any way negatively. Research came up empty on this one so I just ignore it every time.
golfdave
Scotland (U.K.)
Ride
MK7 Golf GT Estate
Finally got around to scanning my car which I have set the DSR to low or off...anyway the lowest setting my module will allow via VCDS...
I have the exact fault cade as the OP....8277 - databus implausible signal..etc..
I have never in the 4yrs of having the car had this fault...& it first occurred (date stamp in VCDS) in October last year....when I turned the DSR to low/off using VCDS....
So that's the cause....I'll reset to normal & see what happens...
