Bump from the dead - The IE downpipe is here and taking up space in my apartment. It a beautiful piece of engineering, and I'm loving the koozie and stickers they sent with it! I should be free to install next weekend! Going to pick up a new gasket from the dealer in the meantime. As per Oddspyke, a Vibrant straight spacer with the medium large insert is ready to go as well. There is one *slight* difference from clamps shown in the online instructions to what I received. Instead of a 2.5 inch slip fit exhaust clamp, they sent a 2.5 inch lap joint connector. I'm going to order a new 2.5 inch slip fit exhaust clamp just to appease my anal retentiveness.
I will attempt to run IE downpipe with AWE Track exhaust. When I get annoyed with that, I am debating whether to throw the OEM exhaust back on or cutting/clamping/welding in a Vibrant 17950 Vibrant resonator to the AWE midpipe. Or ordering Jake's AWE resonated midpipe. Or biting the bullet for the AWE touring section. I am also be interested in running a 3 inch TBE. Thinking a 3 inch clamp (Butt joint? Lap Joint?) and a new section of 304 stainless exhaust pipe mated to the AWE catback might work. Ideally, I'd like to run a length of slip fit pipe from the downpipe and mate that up to the exhaust, but I am having difficulties finding something pre-fabbed. What I don't know about fabrication can fill a book lol.
I am not sure what my final exhaust set up will be and I don't know how to weld, so keeping my options open and easily reversible are important to me, but an exhaust comprised of hella clamps doesn't sound ideal either.
While I'm at it, anyone have any tips or tricks for the removal/install? I'll keep researching the boards but figured I'd ask
- I'm planning to remove the oxygen sensor from the car before taking out the OEM downpipe. I think I read it's doable with offset o2 wrench, extensions, and adjustable angle ratchet? Slather copper anti-seize on o2 extension and sensor threads and attach to IE pipe before install?
- To help the get the old pipe out, I want to twist counter clockwise as I try to work it out correct?
- Anything else that might make my life easier?
Thanks in advance!
