My spacer is still on there. I have a spare phone running Torque and an obd2 adapter so it automatically clears any CEL. But I still get P013E.
I'm dealing with a very slight occaisional rattle so will probably try tweaking my spacer to see if I can get it to go away when I try to fix that.
Initially I had a lot of rattle then I loosened everything and put a balled up rag between the dp and the heat shield bolt. Tightened everything while under that pre load then pulled the rag out. Now only occaisionally rattles under a lot of load.
Sent from my SM-N910V using Tapatalk
I'm going to get under the car and look for this heat shield bolt. I don't feel anything touching the downpipe, the closest distance between an object and the downpipe is about 1 finger gap
