DIY: Virtual Cockpit Retrofit MK7 (aliexpress version)
FixIt
MK7.5 GTI
This is a great tip! Where did you use this on yours? Which plastic to plastic areas? Trying to visualize where exactly. I'll definitely be doing this when I install it on mine. (y)
When you take the dashtrim off, you can see all the surfaces where plastic can rub against other surfaces, either from the car dash or other plastic trim pieces. Temperature based expansion will also cause creaks, at least in my car and driving over bumps or rough road surfaces. The dash trim is clicked inside metal spring-loaded clips and I placed the tape over every plastic piece that goes in those clips. Also the back of every trim piece that touches other areas has now a small thin piece of this tape. I didn't take photos of this process but used tape whereever possible l, without it becoming visible when looking at the dash. The tape is thin enough that it will stay inside the metal spring loaded clips without causing space restrictions.
I also used this tape for the sunglass cubby, the sunroof, the arm rest and the glove box. It is black so you don't see it, but it prevents rattling and creaking quite effectively. There are several blogs and YouTube videos on specific GTI rattles and every generation has its own unique issues with that. It just bugs me beyond belief and this tape really helped.
Lori87Mi
Italy
MK7
@FixIt
Hi, I found these 2 videos on how android auto/apple carplay mirroring works:
from what I understand the seller must provide a connection box that connects to android auto on the MIB USB and has an HDMI output and I see that it also has another USB perhaps to connect the smartphone and activate android auto.
I think it is a kind of splitter box that intercepts the video and sends it to the digital display
UPDATE: i have found the seller and all the product needed to complete the configuration:
Update: buyed and installed this 3 components and work as expected. Android of the carplay box is mirrored into digital cluster via hdmi.
Important to know, vendor need to be advised before shipping because he need to modify the digital cluster to add the hdmi port.
FixIt
MK7.5 GTI
Nice, it won't work for my cluster though, based on feedback from my seller. But I'm glad you were able to find a solution that works ?
Lori87Mi
Italy
MK7
I wanted to ask you, my car has the ECO "2 cylinder mode" function. On this digital cluster the warning is not shown when the ECO mode comes into operation.
Is there a way to have it?
I also don't understand two other things:
the radio station names are cut, do you too? here an example, radio station icon not present, and radio station name is only the first letter
and how did you configure the tank capacity? if I insert 50 liters and fill up at the gas station the needle does not go to maximum, I have to insert 48 liters
Thanks
FixIt
MK7.5 GTI
Thanks
Regarding Eco mode, depending on whether I select Normal, Sport, Comfort or Eco mode, I see D, S, C or E in the left dash clock.
I never listen to the radio, so I'd have to check that, however when I play music from Tidal or YouTube music, long names are always cut-off. It doesn't really bother me to be honest.
The gas tank capacity, how much gas is used (in liter of gallon), or speed deviation can be adjusted in the settings. I never had to set the gas tank capacity but I did have to set an offset to the speed in order to match GPS speed. I'll take some pictures of what I see.
FixIt
MK7.5 GTI
I got a chance to take a few pics. Under settings is a menu called calibration where you can calibrate the tank and speed offset.
With FM radio I don't see text in the digital cluster, with media (Youtube music for instance) I do.
Sorry, I didn't include a picture with E, but in eco mode it would show up in the place where it says 'P' below. I dont think I ever saw a difference in mileage between E or D, but it may be too small to stand out.
It looks like media names are shown in full, but FM radio just shows frequency and no further text. As long as the sound is great, I don't really care what it says (or not says) in the dash, since the headunit shows all song info as well.
By the way: your picture shows a range of 790km, that's 493miles! That doesn't seem correct since all mk7.5 golf GTI's have a similar gas tank size of 13.2 gallons or 50ltr. Perhaps another setting is not set properly. Did you configure the dash for a Golf and sport? There are several car options, including Passat I believe, and perhaps that is selected since it has a larger tank size?
srut2000
Texas
2019 GTI Rabbit
Does anyone have a link to the cluster y'all recommend on AliExpress and the car play box. Would love to do this to my 2019 Rabbit GTI.
FixIt
MK7.5 GTI
The link to my digital dash is at the bottom of page 4 of this thread and I pasted it below as well. I love my dash, no issues besides a few minor quirks which are all described in detail in the last 12 pages.
My cluster supports phone mirror to the center of the dash as well, so you can see Google Maps in between the dials. With my dash, that only works wirelessly and the phone gets pretty hot. I don't really use this feature to be honest and to me it is more like a cool party trick with little real world use.
There are apparently other digital dashes out there that can use a wired mirror instead of wireless. The mod itself requires plastic tools to remove dash trim. It takes some patience but it is very doable!
I also posted links to YouTube videos in some of these pages, so take a look around and absorb all info before you start the mod.
I'd look around on AliExpress because there are many dashes and some may have different features and prices. Or you are welcome to get the same one i have, since it works really well and you can see plenty of pictures in this tread :)
I found the link to the cluster that I bought:
https://www.aliexpress.us/item/3256...param-url=scene:search|query_from:#nav-review
Jaime2823
Chicago
So where does the box connect to? So one cable goes to the cluster and the other to the usb port in the tray ?
Lori87Mi
Italy
MK7
yes, hdmi output of the box to the digital cockpit hdmi input, and the usb to the usb port of the car enabled for android auto/carplay
there are many box with hdmi output port, i think the best (but the more expensive) is the Carlinkit UHD Tbox https://www.carlinkit.store/product...60-8-core-split-screen?variant=45140191707274
I add that I am waiting in these days for some LVDS cables, I want to try this scheme so as not to need a connected Box anymore:
bobloblawGTI
DC
19 GTI SE 6MT
View attachment 310404View attachment 310405View attachment 310406View attachment 310407
Do you have a 2021 by any chance? Wondering if your radio interface looks different because of the MIB3.
Jaime2823
Chicago
How is everyone connecting to their clusters for screen mirroring? I tried looking for a bt connection with my iPhone but does not find anything.
FixIt
MK7.5 GTI
Screen mirroring works through WiFi, not Bluetooth. For my android, I pull down my screen from the top twice and select "Smart View, Mirror Screen".
For iPhone I believe you need to swipe up from the bottom and select screen mirroring (AirPlay). You may need to select a wifi ID and PW and these should show up in your dash in that blue screen (see below).
There are other options as explained in the messages above, which involves a cable and a cluster with a specific hdmi connector that is active (not all dashes have this), and a module.
Jaime2823
Chicago
Do you need to access that screen for screen mirroring? Because I can’t find that screen and when I try to mirror on WiFi it still won’t find the cluster
