Hi. I would like to ask you to show me what lamps I need. I am from Poland and I need European lamps. My VW Golf 7 is from 2013 and now has halogen lamps (regular BG1 1.2 TSI 105hp hatchback). I want to change to BI-XENON with LED daylight, no turn.
Hate to bring a thread this old up, but I was thinking about doing this on my 17' Alltrack, and using Euro R Lights. Does anyone know if the wiring is different on those lights, or should these wiring diagrams work?
@George Ab there is this video of the Mk7 headlight completely disassembled. At 4:35, I can only see one motor. Do you have any idea how that single motor is able to adjust the lens in both up/down and left/right movement?
Hi! Since you have Bi-Xenons, this would imply you have an MK7 and not the MK7.5. I performed this retrofit on my car here in the US. The good thing, being that you're in Europe, is that you, or someone you can find to code, would only need access to something like VCDS or OBDeleven to perform the coding changes. I have posted the necessary equipment and coding changes to make everything function here.
