Were you not able to put your OE engine cover bracket back on with the OE rail? I bought one to try and fix that issue with my A2B rail.Getting close. Wiring needs tested and tune activated.
I cheated. Put in another circuit 12VDC to 5VDC 5A Converter Step Down Regulator 25W transformerhow do other harnesses get the 5v power for the lpfp sensor?
It's on. Hose was rubbing a bit. I stole from somewhere else to protect it. SAI hose bushings are nice to cut down and stop rubbing. Electrical tape around it and almost looks stockWere you not able to put your OE engine cover bracket back on with the OE rail? I bought one to try and fix that issue with my A2B rail.
I had read that, i was curious how other companies harnesses were pulling 5v - appears its from an intake runner position sensor?I cheated. Put in another circuit 12VDC to 5VDC 5A Converter Step Down Regulator 25W transformer
Yes pulling electricity from the flap sensor will cause a fault, maybe they tune it out perhaps someone else can chip in. But fwiw the $12 transformer and $3 for add a fuse was. $$ > TimeI had read that, i was curious how other companies harnesses were pulling 5v - appears its from an intake runner position sensor?
You mentioned that pulling the 5v from that sensor caused some codes?
You need a custom tune. Row cars with mpi are only running something like 160cc injectors. The priority tables on combustion need changed, the injector pw and dead time will be wrongDoes this require a custom tune? Or are there off the shelf tunes that activate them at cold start or however they are used in europe.
M6x1 x 40 be my guess. It's pretty closeSaw your bolt specs were based on the inserts you're using. Any idea what the thread is on the Euro manifold that comes pre-threaded?
United has MPI as an add-on to their tuneDoes this require a custom tune? Or are there off the shelf tunes that activate them at cold start or however they are used in europe.
We can definitively say that a correctly wired flap sensor piggyback does work.Yes pulling electricity from the flap sensor will cause a fault, maybe they tune it out perhaps someone else can chip in. But fwiw the $12 transformer and $3 for add a fuse was. $$ > Time
Are you attempting to loop the flap sensor for power and ground to the LPFS?Hi, I will make the same operation near future. But I need few more info about wiring. Can somebody tell me how to connect 3pin connector (4F0973703) Male & Female version to manifold flap control? Thanks in advance for help
