7umberjackZac
- Pittsburgh, PA
- Gti
Disclaimer:- This info is for community usage only. You are welcome to use the information contained in this thread, but I take NO responsibility for any discrepancies, injuries, or catastrophic damage that results from improperly modifying your car. You assume all liability when YOU decide to wrench on your vehicle. Messing around with fuel systems is inherently dangerous and if you do it wrong your car could end up burning up in a fire or worse you could die in a fire. Do your own research before attempting any type of DIY project and confirm part numbers and necessary tools necessary. I do NOT represent any company or receive affiliate compensation from any person or company. I'm just a guy that has spent A LOT of time reading and researching to share my opinions. NO GUARANTEES are offered. To be clear I do NOT recommend making your own MPI kit but if you do, here's how.
I'm doing my best to update this
Objective:- Run Multi-port Injection on USDM MQB vehicles with "responsibly sourced recycled parts" for those wanting to be green and run ethanol.
- Golf/GTI/GolfR/Tiguan/GSW/A3/A4/S3/A5/TT/Q3/Q5 Basically any vehicle with the EA888 Gen3 Engine that can be tuned.
Existing solutions:-
MPI kit_______________$722-1300
LPFP kit______________$299-1300 (305/450/525/brushless)
Fuel controller 40a __$650-675 (for brushed fuel pumps 450/525)
Cobb or similar______$675
Tune_________________$375-550
A whopping total of $2072-3725
Why would you want MPI? :-
-More fueling for more power
-Clean intake valves from carbon
-Hybrid Turbo setup
-Because it's OEM in Germany
-Under $600 MPI on OEM parts, opens the door Mo-powa Buhbay
What's the absolute minimum to make this happen? :-
1) Low-pressure fuel rail (OEM used under $80)
2) Fuel injectors (OEM 125cc or 980cc or 1300cc $0-450)
3) 5/16 OEM or 3/8 Oversized T-split ($12)
4) Hose clamps ($12)
5) Wiring harness (DIY cheap)
6) Modifying intake manifold ($8 drill bit and $5 for socket)
7) Tune to activate the injectors
HPtuners, Open source tuning or the usual suspects to activate this for as little as $150
Parts list:-
1) European Fuel rail - 06K133681C, 06L971627M, 06L906031A or similar.
Seat Leon, Skoda, Audi, VW worldwide all use the same low-pressure rail.
Often they come used with fuel injectors, low-pressure sensor, and even wiring, connectors.
2) LP Fuel sensor - (06H906051J) or similar
3) Fuel injectors - Bosch EV14 CKxT 980cc. (0 280 158 040) if you want to use OEM get new seals for them. OEM 06L 906 031A or similar.
Don't buy counterfeit injectors from sketchy places. Unfortunately, there are TONS of these being sold super cheap because they are fake. Often come with Bosch Jetronic to OEM. They will leak, they can stick wide open.
4) LP fuel pump/kit - Walbro 305 (F90000265) or Walbro 450 (F90000274) or Walbro 535 (F90000285) or full drop in replacement RS3 Fuel pump brushless. (Open source community has accomplished this)
If you want to run 980cc injectors or higher you will need a fuel pump.
5) 5/16 T-split or larger
6) 5/16 fuel hose or larger
7) Hose clamps
8) 5-6 ECU pinned wires - Repair wire
J623 (105pin)/ J283 (91pin) ECU connector with a few inches of wire. (4H0906971A)
Your best option is the entire connector and just de-pin it. 2011->2018 VWAG should work.
9) 3pin D connector (4D0971993)is a fairly common connector in late 2000s Audi/VWs. I managed to find 2 at the junkyard
10) 8pin D connector (4H0973714B) is optional, you could just bypass this connector. $8-18
11) 3pin connector (4F0973703) Male & Female to manifold flap control. Also listed as PDC sensor extension
12) ATC fuse terminal Easily sourced from any 2000-2018 VWAG vehicle fusebox
13) Threaded Insert Kit I used this but there are plenty of options.
14) a tune
15) Odd and Ends-
M6x1x40mm bolts (2)
Drill guide
Zipties
fuse
Fabric wiring loom wrap
14 gauge wire about 4 feet - $4
20 gauge wire about 30 feet- $15
EV14 to OEM 2 pin $0-30
Tools List:- (*)optional
VW depinning toolset
Hand drill
7mm drill bit
Wire stripper/crimper
* Crimper for VW connectors
Channel-lock plier
Needle-nose plier
* Heat gun
1/4 drive socket driver
3/8 drive socket driver
T25 bit
T30 long reach or bit with extension
7mm socket
10mm socket with extension
13mm socket
17mm wrench or crowfoot
21mm wrench
10mm Triple square
Pick set
* Flashlight
* Magnet reach tool
-Hybrid Turbo setup
Parts list:-
7) Hose clamps
14) a tune
15) Odd and Ends-
M6x1x40mm bolts (2)
Drill guide
Zipties
fuse
Hand drill
7mm drill bit
Channel-lock plier
Needle-nose plier
* Heat gun
T25 bit
7mm socket
13mm socket
21mm wrench
10mm Triple square
Pick set
* Flashlight
* Magnet reach tool
