DIY MIB2 Infotainment Conversion into 2018 "S" Models
quailallstar
WOB DJ496
Florida & our Nation's Capital
MY19 MK7.5 GTI Bunny
@DV52 or someone else who may know coding very well. All is perfect with the MIB2.5 setup including CP removal. Because my MIB2.5 unit came out of an Atlas SEL R-Line it still has some leftover programming I can't seem to un-code. See some VCDS errors below and someone let me know where/what to poke around under to get this all error-free. I realize the Sat radio error is due to not being activated.
Code:
Thursday,19,December,2019,18:54:25:61205
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 29 2B 32 39 3C 42 44 4B 52 5F
          A9 D6 D7
VIN: 3VW6T7AU6KM006717   Mileage: 7194km-4470miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
29-Left Light -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
32-Differential Locks -- Status: OK 0000
39-Right Light -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     722 0867
   Serial number:
   Coding: 02731000FF00000051221001001828001F0503D401200501C2
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2E050E489099B4276BB-807A
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJT2946449
4 Faults Found:
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 7194 km
                    Date: 2019.12.19
                    Time: 04:11:11
                    Voltage terminal 30: 11.7 V
                    Byte_Coding_Condition-byte_0_condition: OK
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: OK
                    Byte_Coding_Condition-byte_9_condition: OK
0020 - Tuner for Satellite Radio
          B11CF 53 [009] - Deactivated
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 7194 km
                    Date: 2019.12.19
                    Time: 04:11:32
                    Voltage terminal 30: 11.8 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Channel selection for satellite radio: 0
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 47 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
2565 - GPS Antenna
          B1054 13 [009] - Open Circuit
          [GPS aerial - open circuit]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 7194 km
                    Date: 2019.12.19
                    Time: 04:11:12
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [A/C system (0x02) - function restriction due to communication error - BapErr_retry not successful]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 7194 km
                    Date: 2019.12.19
                    Time: 04:11:14
                    BAP-BAP_Function_ID: 02
End----------(Elapsed Time: 01:34, VBatt start/end: 12.1V/12.1V)-----------
DV52
Australia
quailallstar: I replied to this same matter in the RT forum - hope you saw my response there
Don
quailallstar
WOB DJ496
Don
Happy 2020 Don! No, I didn't see your reply over on the VCDS forums. Heading over there now to take a look. ;)
Thanks,
Michael
w124_karl
NC
This might be a bit too ambitious for me, but I just wanted to thank the OP a for such a fantastic, well written DIY. Many thanks for doing it!
GHO5T7
HTX
2018 GTI S /MT
Hello All! And Happy 4th of July to people in America!
I am currently in the process of gathering the parts necessary to perform this upgrade from my 6.5” unit to the 8” unit. I have a 2018 GTI S and I have ordered most of the parts and hopefully will get them within the next month. I wanted to double check some things as I still unsure about a couple things.
It mainly resolves around the component protection, CarPlay/Bluetooth/Voice activation, and vcds VAG COM.
While I was reading through this guide and the others linked in this post, I see that even after switching the equipment out that some things were not functioning. I wanted to see if “quailallstar” or “stuntnuts” if you were able to have your setups 100% working, like the Rear-view camera, carplay, USB connection etc. And how you were able to fix the issues you had.
What problems did you have to visit the dealer for or use vcds VAG COM to fix anything or have Jack fix the issues? I’m a little worried about the component protection and the FEC activation portion of things as I don’t think the dealership that I normally go to is necessarily Mod Friendly but I guess I will find out once I go if I have to.
I haven’t used VAG COM since my ’03 Golf TDI many years ago so I honestly don’t know what it does anymore or what its need for in this application. What things are needed for it? And does anyone have any recommendations for what cable to use as I currently don’t have one anymore…
I do plan to get the Helix sound system in the future like quailallstar, were there any issues having the Helix sound system?
For reference I am going to be going with the NON-NAV setup way so I picked up the below parts.
3Q0 035 844 B (from a 2018 atlas)
5G6-919-605-C (from a 2019 golf I think?)
Looking forward to your responses, thanks!
sprinks
United States
Easiest to work through Jack tbh. Dealerships don't really know what they're doing once you start swapping stuff out. When i did CP and mib2 swap on mine, they literally were using the forums here to figure out what to do.
Dealerships can typically handle the Comp Protection removal if you can manage the install and necessary rewiring. It shouldn't be as much of an issue since your VIN has all the appropriate FECs currently, but it's a big should tbh, and i'm more interested in working with someone interested and familiar with the goal of the project.
GHO5T7
HTX
2018 GTI S /MT
Thanks for your reply, I reached out to Jack and he provided me with the information of what I need for him to do his job.
For anyone wondering you'll need
vas 5054a +
d-link dub e-100 +
ethernet cable +
sd card +
windows pc with teamviewer installed
After looking for the VAS 5054a I'm noticing my options of getting one are really limited.
Does anyone know where to source one? Most of the ones are in China with a 2 month turnaround order time....
uranorab8
San Francisco, CA
2019 GTI Rabbit
@stuntnuts Just wanted to thank you for posting this DIY up. I definitely would have not taken this on going in blindly but your DIY made it easy. Now I just need to wait for Jack, no luck in getting a hold of him yet.
Some pictures or tips I thought would be worth adding in
1. I couldn't find where to plug the glove box hose (eventually found it but it took a while). Here's a picture of what it looks like. This is taken down in the footwell from the passenger side. As posted in the DIY, it's covered with a little rubber cap,
2. I found that removing this big plastic divider piece made it way easier to fish the quad extension harness to the glove box area. It's held by one screw and about 4 plastic trim snaps
Done!
stuntnuts
Maine
Done!
You are welcome. Thank you for having the bravery to attempt it. There's only a VERY select few of us out there.
H22hatch
Vienna VA
I just had Jack connect with me last week to remove CP and code in my fec's for my car. The teamviewer application is used for enabling FECs like Carplay, Voice command, performance monitor, etc.
Right, but what exactly did he do? I know he had to have used odis but how did he run odis on your machine?
sprinks
United States
He runs all the applications and everything on his side, using TeamViewer as the portal to your machine's connections. That's why no one has to download ODIS or other software and you literally only need the cables/connections mentioned.
