quailallstar
WOB DJ496
- Florida & our Nation's Capital
- MY19 MK7.5 GTI Bunny
@DV52 or someone else who may know coding very well. All is perfect with the MIB2.5 setup including CP removal. Because my MIB2.5 unit came out of an Atlas SEL R-Line it still has some leftover programming I can't seem to un-code. See some VCDS errors below and someone let me know where/what to poke around under to get this all error-free. I realize the Sat radio error is due to not being activated.
Code:
Thursday,19,December,2019,18:54:25:61205
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 29 2B 32 39 3C 42 44 4B 52 5F
A9 D6 D7
VIN: 3VW6T7AU6KM006717 Mileage: 7194km-4470miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
29-Left Light -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
32-Differential Locks -- Status: OK 0000
39-Right Light -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 844 B HW: 3Q0 035 844 B
Component: MU-S-S-US 722 0867
Serial number:
Coding: 02731000FF00000051221001001828001F0503D401200501C2
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 2E050E489099B4276BB-807A
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C
Component: ABT_Std-2 H50 8130
Serial number: VWZ6ZJT2946449
4 Faults Found:
1543 - Control Module Incorrectly Coded
U1014 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 34
Mileage: 7194 km
Date: 2019.12.19
Time: 04:11:11
Voltage terminal 30: 11.7 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
0020 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 34
Mileage: 7194 km
Date: 2019.12.19
Time: 04:11:32
Voltage terminal 30: 11.8 V
SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
SDARS_tuner_status_2-Channel selection for satellite radio: 0
SDARS_tuner_status_2-Audio Signal: Not available
SDARS_tuner_status_2-Antenna current: 47 mA
SDARS_tuner_status_2-Reception quality: No_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
2565 - GPS Antenna
B1054 13 [009] - Open Circuit
[GPS aerial - open circuit]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 34
Mileage: 7194 km
Date: 2019.12.19
Time: 04:11:12
7170 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[A/C system (0x02) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 34
Mileage: 7194 km
Date: 2019.12.19
Time: 04:11:14
BAP-BAP_Function_ID: 02
End----------(Elapsed Time: 01:34, VBatt start/end: 12.1V/12.1V)-----------
