DIY MIB1 to MIB2 Infotainment Conversion (Part 1)
Lth0ms0n
United Kingdom
2013 Golf GTD
I don't remember the carbon texture, haha. I also don't recall how to change the menu type. I think mine is a grid, but also scrolls to a second page. There's an option that's one row with left-right scrolling too, correct?
It's a GTI/GTD thing which probably went with the Mark 7.5, when the interior trim was swapped for the gloss black. When you're looking at my old MIB1 display, you can see the texture of the trim carried through it. The MFD by the speedo is the same:
It's difficult to see it on the old 5.8" display due to the crappy resolution - it's easier to see in the dark.
I went through a load of different long-coding options on my OBD11 last night, looking for it, but couldn't find it. It's not a deal breaker but if I can get it to look the way it did before when this is all finished, I would prefer it.
Also, is it possible to change the car that's displayed in the Car menu to look more like mine and less like an SE with the GT alloys on it? I can get an Estate to display by changing the variant etc but it didn't seem to want to change much more than that. I wasn't restarting the 5F every time I coded it though, which could be why...
Cuzoe
Yeah I think you have to do the full restart. My MIB II had what looked like a GTI/GTD, a standard Golf, a facelift (7.5) Golf, and then a wagon or two as well... The graphic I have now looks to have the 7.5 Euro tail lights, I'm actually not sure what the front looks like, haha.
Lth0ms0n
United Kingdom
2013 Golf GTD
I figured as much. It was becoming very time consuming waiting for OBDeleven to reconnect and pull the data through every time but by this stage it was getting late and I gave up.
I've got the Dynaudio HIM startup sticker sorted at least! Just tried that now.. It doesn't flash the GTD badge at start-up first though, it seems to have replaced that with the Dynaudio one (it would flash GTD then Dynaudio then the menu on my MIB1) is that normal/MIB2 behaviour? I'm not actually sure my unit is shutting itself off correctly, it doesn't respond if you push the power button.
All of this just tinkering though, Simaservis gets his hands on it later today so I'm sure all these oddities will get straightened out then.
Cuzoe
Yea, he'll get it sorted I'm sure. The Fender/Dynaudio "badge" is in the adaptations as "Startup Sticker" or something like that. The different model badges (GTI/GTD/GTE/e-Golf/etc.) are done in long coding. I just noticed my MIB 2.5 is showing a Powered by Dynaudio sticker, which is incorrect... now you've created work for me, haha. Maybe I'll choose the Family badge as there's nothing for TDI :cautious: .
Lth0ms0n
United Kingdom
2013 Golf GTD
So, I'm nearly there with my retrofit and I'm really pleased - I get Dolby Atmos audio in my car now and actually, with the Dynaudio speakers, it sounds really good! I've just got a few teething problems to sort and I should be good to go (at least, until Apple finally ditch the lightning port, after which I'm back to square 1...). I'm just waiting on Simaservis getting some configuration files from VW to re-enable the Dynaudio sound pane on the unit so I can get it set back to the way I like it.
I can't seem to get the navigation to appear on the MFD - is this a simple coding change and can it be done using OBD11?
I have a VW Navigation SD Card - it has 2020's last map update on it currently. It works (or at least, it did) until I update it (using Discover Care) but when I do that and put it back in the car, it doesn't recognise it. I've tried using Discover Care and also doing it manually (following the guide document to the letter) but neither process seems to work. To really add insult to injury, Discover Care seems to have f*cked the card entirely now - when it stopped working post-update, I could restore the back-up of it that I took but twice this morning, I've tried that and both times, it's failed. Right at the b*stard end, too...
The card is genuine (P/N 5NA 919 866 S) and when it works, the database on the card is 1310 ECE1 2020. Discover Care attempts to update it to 1410 ECE1 2020/21 - at which point, even though it says it was successful, the unit stops reading the data.
My understanding of this was that the Discover Media units had lifetime support for their Sat Nav databases:
Does this only apply to later MIB units, or is this all of them?
Lucky#Slevin
Staten island
Just installed the 8” all glass display and found a new OEM part # for the polar night grey 8” radio trim with vents.. 5G1-819-728-AG-EVO. Got it for $103 from vw parts vortex..
Mark_evich
Los Angeles, CA
2015 Golf TDI Mk7
Hey everyone,
another MIB2 retrofitted into mk7! :)
First of all, thanks to @George Ab for renting out his equipment, and thanks to @simaservis1108 for his patience with semi-noobs like me. It's because of people like George and Sima we're still here on this planet!
Brief description of the process!
My car:
2015 Golf TDI with Mib1 and Fender Audio, no USB, 5 inch display
What I needed:
Parts:
Mib2 headunit
[Ebay, $140]
6.5 display [Ebay, $100]
USB+Aux Harness [Ebay, $40]
USB + Aux connector [made a mistake of ordering harness WITHOUT the connector, so had to buy a connector from an official stealereship for $60 - make sure to order yours on AliExpress or Amazon, since you'd save a lot of money, just do it in advance. I decided to spend this money, since I didn't want to wait any longer]
Tools:
Vas5054a
[rented from @George Ab ]
D-Link Dub e100 [rented from @George Ab ]
Dedicated trim keys to remove both MIB headunit and the screen [rented from @George Ab ]
Knife to adjust the harness to fit the new screen - though Dremel tool is preferable
SD Card
Windows-based laptop [
rented from local Rent-A-Center for $20 bucks for a whole week[
LAN cable
SD card reader [
my laptop didn't have an SD card port]
Another Ethernet USB adapter (brand doesn't matter for this one) [bought and returned to Best Buy]
Fiberglass Pull Rods to pull the new harness from the glovebox to the cubby [Harbor Freight, $7]
Process:
Once you got all the right parts and tools, the process is really fast. It's described in the article provided in the starting post of this thread. Just make sure to follow the instructions and don't skip any parts unless you know why you skip them. For example, you'll need to pull the old harness off a block connector in the head unit and replace it with the new one, so make sure you do so; your USB port part number must be one of those that support Carplay - even if you got USB port, you are not guaranteed to have CarPlay; you'll have to cut a few ridges off some of the cables so they fit - nothing crazy (just don't get frustrated if something won't fit - most probably it's just those ridges preventing this, so don't worry).
Like everyone else here says, fishing the cable from the glovebox to the cubby would be the most difficult (relatively) part, but having the fiberglass rods or any other tool would help immensely.
After the physical replacements are done, time to call @simaservis1108, who will do everything for you. Make sure the connection is good, install TeamViewer, and make sure to have ALL of the things I mentioned to avoid having to run back and forth.
DO NOT BUY ANY ACTIVATION CODES
DO NOT GO TO THE DEALERSHIP TO REMOVE CP
DO NOT BUY MIB2 AMP FOR YOUR FENDER - YOUR AMP WILL WORK JUST FINE (UNLESS YOU WANT TO HEAR SOME SEXY SOUND IMPROVEMENTS)
- you'll waste your money.
Just do the replacement and simaservis will take care of the rest.
I'm glad to answer any questions as I have the most recent information about the process as of today! :)
ash9949
Poland
golf 7
Date: 2021-07-18 22:13
VIN: WVWZZZAUZEW0XXXXX
Car: Volkswagen Golf
Year: 2014
Body type: 5-dr hatchback
Engine: CRBC
Mileage: 130621 KM
Fault
Control unit: 01 Engine
Active faults: 0
Inactive faults: 0
System description: R4 2,0L EDC
Software number: 04L906021DS
Software version: 8125
Hardware number: 04L907309D
Hardware version: H22
ODX name: EV_ECM20TDI01104L906021DS
ODX version: 002013
Faults:
No trouble codes found
Mileage: 130411 km
Date: 2021-07-18 12:08
Fault
Control unit: 03 Brakes
Active faults: 0
Inactive faults: 0
System description: ESC
Software number: 5Q0907379CK
Software version: 0472
Hardware number: 5Q0907379G
Hardware version: H31
Serial number: 622730000001AB
ODX name: EV_Brake1UDSContiMK100IPB
ODX version: 033001
Faults:
Mileage: 130411 km
Fault
Control unit: 08 Air Conditioning
Active faults: 0
Inactive faults: 0
System description: Climatronic
Software number: 5G0907044AA
Software version: 0705
Hardware number: 5G0907044AA
Hardware version: H02
ODX name: EV_ACClimaBHBVW37X
ODX version: 003018
Faults:
Mileage: 130411 km
Fault
Control unit: 09 Central Electrics
Active faults: 0
Inactive faults: 1
System description: BCM MQBAB H
Software number: 5Q0937084AA
Software version: 0112
Hardware number: 5Q0937084AA
Hardware version: H14
Serial number: 00011323201682
ODX name: EV_BCMCONTI
ODX version: 011001
Faults:
B136604 - Rain/light recognition sensor Faulty
static
Mileage: 130411 km
Fault
Control unit: 15 Airbag
Active faults: 0
Inactive faults: 0
System description: AirbagVW20
Software number: 5Q0959655C
Software version: 0361
Hardware number: 5Q0959655C
Hardware version: 011
Serial number: 003F5R07A52V
ODX name: EV_AirbaVW20SMEVW37X
ODX version: 002126
Faults:
Mileage: 130411 km
Date: 2021-07-18 12:09
Fault
Control unit: 16 Steering Column
Active faults: 0
Inactive faults: 0
System description: Lenks. Modul
Software number: 5Q0953507AA
Software version: 0070
Hardware number: 5Q0953549
Hardware version: 007
Serial number: 09081304220558
ODX name: EV_SMLSKLOMQB
ODX version: 009001
Faults:
Mileage: 130411 km
Fault
Control unit: 17 Dashboard
Active faults: 0
Inactive faults: 1
System description: KOMBI
Software number: 5G0920861A
Software version: 2210
Hardware number: 5G0920861A
Hardware version: 252
ODX name: EV_DashBoardVDDMQBAB
ODX version: 008031
Faults:
U111000 - Function restriction due to communication interruption
static
Mileage: 130411 km
Fault
Control unit: 19 Gateway
Active faults: 0
Inactive faults: 1
System description: GW MQB Mid
Software number: 5Q0907530L
Software version: 1144
Hardware number: 5Q0907530E
Hardware version: 124
Serial number: 0000873887
ODX name: EV_GatewLear
ODX version: 009013
Faults:
U110100 - Component protection active
static
Mileage: 130411 km
Fault
Control unit: 42 Driver Door
Active faults: 0
Inactive faults: 0
System description: TSG FS
Software number: 5Q0959593A
Software version: 0006
Hardware number: 5Q0959593
Hardware version: 012
Serial number: 07081306071094
ODX name: EV_DCUDriveSideEWMAXKLO
ODX version: 006003
Faults:
Mileage: 130411 km
Fault
Control unit: 44 Steering Assistance
Active faults: 0
Inactive faults: 0
System description: EPS_MQB_ZFLS
Software number: 5Q0909144L
Software version: 1021
Hardware number: 5Q0909144M
Hardware version: 127
ODX name: EV_SteerAssisMQB
ODX version: 008022
Faults:
Mileage: 130411 km
Fault
Control unit: 52 Passenger Door
Active faults: 0
Inactive faults: 0
System description: TSG BFS
Software number: 5Q0959592A
Hardware number: 5Q0959592
Serial number: 10081303110926
ODX name: EV_DCUPasseSideEWMAXKLO
ODX version: 006003
Faults:
Mileage: 130411 km
Fault
Control unit: 5F Multimedia
Active faults: 0
Inactive faults: 5
System description: MU-S--ER
Software number: 3Q0035824B
Software version: 0363
Hardware number: 3Q0035824B
Hardware version: H30
Serial number: VWZAZ2T1093754
ODX name: EV_MUStd4CTSAT
ODX version: 001022
Faults:
B201A00 - Checking software version management
Intermittent
static
U111100 - Function limitation due to missing message
static
static
U11B800 - Interface for external media No communication
static
Mileage: 130411 km
Fault
Control unit: 76 Parking Assistance
Active faults: 0
Inactive faults: 0
System description: PARKHILFE 8K
Software number: 5Q0919294C
Software version: 0033
Hardware number: 5Q0919294A
Serial number: 94231323901279
ODX name: EV_EPHVA18AU3700000
ODX version: 002019
Faults:
Mileage: 130411 km
Date: 2021-07-18 12:10
hi everyone im new here i had retrofitted mib2 hacked head unit there is no CP displayed on screen nor i have problem with sound, everything works expect these errors i see all time i tried deleting these error but these seems to come back again and again
and just igonore the rain sensor because i had crak on windshield so i have change the glass as soon as possible only error worry me is this gateway module error and infortatinment error
can anyone with knowledge of coding can help
yes mib2 headunit was hacked with emcc method
ash9949
Poland
golf 7
Fault
Active faults: 0
Inactive faults: 5
ODX version: 001022
Faults:
Intermittent
static
static
static
static -> this error because im still using old usb port which came original with my mib1 but android auto is working with this old usb so i didnt buy the android auto usb for this retrofit
ash9949
Poland
golf 7
Year: 2014
Engine: CRBC
Mileage: 130621 KM
Fault
Active faults: 0
Inactive faults: 0
ODX version: 002013
Faults:
Mileage: 130411 km
Fault
Active faults: 0
Inactive faults: 0
ODX version: 033001
Faults:
Mileage: 130411 km
Fault
Active faults: 0
Inactive faults: 0
ODX version: 003018
Faults:
Mileage: 130411 km
Fault
Active faults: 0
Inactive faults: 1
ODX version: 011001
Faults:
static
Mileage: 130411 km
Fault
Active faults: 0
Inactive faults: 0
ODX version: 002126
Faults:
Mileage: 130411 km
Fault
Active faults: 0
Inactive faults: 0
ODX version: 009001
Faults:
Mileage: 130411 km
Fault
Active faults: 0
Inactive faults: 1
ODX version: 008031
Faults:
static
Mileage: 130411 km
Fault
Active faults: 0
Inactive faults: 1
ODX version: 009013
Faults:
static
Mileage: 130411 km
Fault
Active faults: 0
Inactive faults: 0
ODX version: 006003
Faults:
Mileage: 130411 km
Fault
Active faults: 0
Inactive faults: 0
ODX version: 008022
Faults:
Mileage: 130411 km
Fault
Active faults: 0
Inactive faults: 0
ODX version: 006003
Faults:
Mileage: 130411 km
Fault
Active faults: 0
Inactive faults: 5
ODX version: 001022
Faults:
Intermittent
static
static
static
static
Mileage: 130411 km
Fault
Active faults: 0
Inactive faults: 0
ODX version: 002019
Faults:
Mileage: 130411 km
Ok I had successfully eleminated dashboard error
static.
Because my mib1 had Navi and compass in MFD when looked at long coding I saw that that compass was still active and later I had disabled it a d this error is gone
And the by the way these forum semms to dead to me , I had did some research on going through a million webpages of information and analyzing and filtering what I need
Ok, I have 3 more errors to fix in 5F module..
I will post my experience so that someone can find it helpful..
I had mib1(maybe composite media) but with sat nav and Bluetooth with two mic on fenders all factory installed on golf 7 2013 model
And retrofitted with 8 inch screen and mib2 std w/o sat nav
It's a patched unit CP removed on unit everything works including AA, Apple play
Mirrorlink
I went for this option because it was the cheapest
What I could find
ash9949
Poland
golf 7
Fault
Active faults: 0
Inactive faults: 5
ODX version: 001022
Faults:
Intermittent
static
static
static
U11B800 - Interface for external media No communication.
I thinking this error because the usb port I'm using factory installed usb port for for carplay but this this port is working for Android auto , I didn't rested with car play..
Anyway I had order my 726E usb port
I hope this will clear this error
guybenjamin
Newbie
d
After scheduling issues, a failed VAS and a pretty unprepared n00b (me), simaservis1108 was able to get everything configured for me. Thank you so much! I really love the new system and Carplay is a game changer!
