Louiekaps
- Long Beach
- 2015 Golf TDI
You can’t adjust the volume on your device when using app connect.
Can anyone confirm if a “3Q0035844 B“ unit can be used, there seems to be quite a few popping up from Tiguan & Atlas platforms mostly 18/19 year.
I read on another post that revision A units by Delphi are very buggy ?
thanks
Will in-fact work just fine .Can anyone confirm if a “3Q0035844 B“ unit can be used, there seems to be quite a few popping up from Tiguan & Atlas platforms mostly 18/19 year.
thanks
i did have one question. i opted for the 6.5 inch screen with the plans to go 8 inch at some point. if i go 8 inch, is it still just plug and play? is there component protection for the screen? do i need any additional programming? not sure if this has been addressed already, but seeing as this is post number 893, im not sure im up for reading through all 892 previous posts for this little tidbit of info..... so i apologize in advance!
thanks for the swift reply and the good news!!Straight swap, nothing else needs to be done, no CP, no other changes required.
No, mib2 amp sounds slightly better but is quite expensive. Mib1 would be cheaper for nearly the same soundIs there a consensus on whether to program a mib1 amp or to just get a mib2 one?
Does anyone have the 5054 cable for sale? Id rather not spend $120 on a cable im going to use one time.
Are you willing to sell it to for $50 shipped?I do. I got it for $80 on eBay when I did my retrofit. It's been staying in its case since then. I'll sell it for $50, plus shipping.
